polizei's Avatar
Originally Posted by draab29 View Post
Can't wait to see how those headlights look!
You and me both
I removed the headlights last week and discovered some rust, cracked headlight-to-fender seals and toasted plug sockets. I've sanded out the rust and put two coats of rustoleum primer on the affected area - should be ready to paint today. New seals and plug sockets are en route. Hopefully I should have these puppies plugged in next week!!
Andy - 1987 911 Carrera Coupe
Old 03-20-2012, 06:29 AM
CaryPhotography's Avatar
Send a message via Skype™ to CaryPhotography
Where did you find those headlights? any links?
Old 03-20-2012, 09:39 AM
polizei's Avatar
911/930 Plug&Play HID Projector Beam Headlights
Old 03-20-2012, 10:29 AM
polizei's Avatar
Update
Things are starting to get interesting now. The engine is dismantled, and much of the machining is complete. Just waiting on the crankshaft to be magnafluxed and micropolished, and the bottom end should be reassembled next week. Below are some pics of the case and heads after a much needed cleaning - sorry for the pic size.
Notice that the heads have been machined to accept the 993 knock bridges. We're going to install them with knock sensors but not actually use them yet. They'll be in place for when I move from Motronic to an aftermarket EFI that supports twin knock plugs. For now, in the short term we'll run stock Motronic with a J&S Safeguard running a single knock sensor on the throttle plate.
Old 06-15-2012, 07:14 AM
polizei's Avatar
Update
Making more progress! The engine should be buttoned up by the end of this week. We haven't finalized the compression ratio yet, but I'm hoping to be in the 10.2-10.4:1 range. Here are some pics of the progress:
Old 07-30-2012, 06:00 AM
CaptainCalf's Avatar
Lookin good!
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 07-30-2012, 08:37 AM
polizei's Avatar
Originally Posted by CaptainCalf View Post
Lookin good!
Thanks Cap'n!
Well, one more step is complete. The car is on its way back up to the engine builder and should be put back together in the coming weeks. I've enjoyed knocking out a dozen or so projects on the car, but I'm just ready to drive this thing!
Old 07-30-2012, 11:44 AM
polizei's Avatar
Another update
The engine is back together and should be in the car mid next week. Then some fine tuning with the new electronics and road testing. Hopefully I'll have the car in my hands within 2 weeks!!
Old 09-21-2012, 11:55 AM
Straight shooter
Lapkritis's Avatar
Engine looks great- look forward to hearing how it runs.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-21-2012, 12:05 PM
polizei's Avatar
Almost there...
Lots of little setbacks, but we're almost there. I've read so many other people's build threads and the delays they encounter... Ten months ago, I would have told you I'd have my car by the end of May. I didn't think the rules applied to me...
Well, the engine is back in and running smoothly. My engine builder had to iron the wrinkles out of a lot of little enhancements I attempted on the car. Everything seems to be coming together well. I'm not sure how common this is among engine builders, but Mark actually does significant road testing on all his engines - separate from dyno tuning. He put 200 miles on the engine so he was confident the rings seated correctly. He then changes the oil, adjusts the valves and re-torques the cylinder heads before delivery. This is a nice QA measure IMHO.
Plan is to pick the car up tomorrow or Thursday... *fingers crossed*
Old 10-23-2012, 12:33 PM
Jitters's Avatar
Send a message via AIM to Jitters
Congratulations on the completion of your rebuild. Good luck and have fun...
1988 930 Turbo...
Old 10-27-2012, 08:43 PM
m110's Avatar
update?
final specs?
1988 Carrera Coupe
Old 08-10-2013, 01:05 PM
How'd you make out?
Old 08-31-2013, 07:20 PM
Your tech 3. R system went to dyno last week.
Old 08-31-2013, 07:21 PM
Ok, a really, really old thread, but I would love to hear from the OP as to how the engine has been in the past 7 years. How many miles, how has it performed and behaved, any issues? What about fuel economy?
Anything you'd do different with the benefit of hindsight? I am getting ready for my 3.4 build using many of the same parts as you....love to hear the experience.
Thanks!
Dennis
Old 03-14-2020, 12:42 PM
