PrimeMvr's Avatar
Pulley removal tips?
The bolt on my 3.0 crank pulley will not budge! I've soaked with PB, tried a two foot cheater bar, cranked my impact gun to 11. No go.
Anyone have a good trick? Thanks, Steve
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 02-28-2012, 09:45 PM
Try a longer cheater bar. I tried my 650 ft lb impact to no avail. The long cheater bar worked great though.
Old 02-28-2012, 11:47 PM
I took the crank to the tire shop and tip the guy a couple bucks. One hit and its off. I dont have the volume needed through a 3/8 hose but the shop does.
Bruce
Old 02-29-2012, 02:46 AM
PrimeMvr's Avatar
It took my wife HANGING on a 4' steel pole slipped over the breaker bar and me standing on the engine stand to keep it from toppling over. Unreal, but it's off! Thanks guys.
Old 02-29-2012, 05:06 PM
What I should have said is, you can still split the case with the pulley on the crank. Thats the way I get the crank to the tire shop, not the engine.
Bruce
Old 02-29-2012, 06:18 PM
Oleg Perelet
Impact should work. I do not even remember if i cranked compressor to 120psi for pulley. Removing rear shock bolts on 964 been much harder.
To remove pulley use this
Oleg
Old 02-29-2012, 06:32 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The crank pulley bolt that gives most people trouble is the type that has a flanged head on it. Underneath the flange its serrated and grips really good (obviously). The name that Porsche calls it in the tech specs is Durlok.
Kevin L
'86 Carrera "Larry"
Old 03-01-2012, 02:28 PM
