964-RSR's Avatar
Mechanical chain tensioner and parts for oil by pass mod
Hi,
I rebuilt my 66 engine and would like to know :
- what Mechanical chain tensioners, chain wheel support ... I should install to improve reliability
- what are parts # (piston, spring, plug ...) I have to change when oil by pass mod is done.
I use chain box year 66 and 68 - 73 camshaft housings, Carrera oil pump mod by Supertec
Here is what I have found on PP forum but would like to be sure before order.
Thank you.
1 - Timing parts : Chain tensioners ...
Right side :
- chain tensioner # 930 105 053 00
- axle support for chain tensioner if used # 901 105 056 01 M100
- chain wheel support from 1980 # 930 105 510 00 or early chain wheel support modified by Supertec or early chain wheel support + chain wheel spacer # 930 105 513 00
- sprocket # 901 105 055 00
- sprocket axle # 901 105 056 01
Left side :
- chain wheel support from 1980 # 930 105 509 00 or early chain wheel support modified by Supertec or early chain wheel support + chain wheel spacer # 930 105 513 00
Chain tensioner slip prevention collars can be fitted on #901 and 930 mechanical chain tensioner # 99 0458 053 M230
2 - Parts for oil by-pass mod
For vertical valve (pressure relief valve) :
- piston # 911 107 512 00 M260
- spring 86mm # 930 107 531 01 M260
- spring guide # 930 107 533 01 M100
- gasket # 900 123 106 30 M131
- plug with groove # 999 064 026 01 M260
For horizontal valve (safety valve) :
- piston # 901 107 512 01 (with hole)
- spring safety valve # 901 107 531 01 M260
Old 03-04-2012, 02:29 AM
Do not get the chain wheel support (a.k.a. idler arm) + spacer combination. The failures in the chain tensioner are related to the narrow arm binding on the shaft. There has been a good photo of this failure recently added to the forum Qucik Chain Tensioner Questions (2)
andy
Old 03-04-2012, 02:27 PM
