Cams and Cam Housings
As we are just about to start machining our forged rockers and we are also looking at buying some cams and I have been trying to figure out the various types irrespective of profiles so we can sort out blanks.
I think that there were the following types: A: 3 bearing, 47mm dia, Centre Lube, External threads. Very Early 911 and 906 ? B: 3 Bearing, 47mm dia, Spray Lube, External Threads 65-68. 911 and may be 74 and 75 2.7 litre CIS C: 3 Bearing, 47mm dia, Spray Lube, External Threads, MFI Drive on Left Hand Cam, MFI Engine 1969 to 1973 D: 4 bearing, 47mm dia, Centre Lube. External Threads, MFI Drive on Left Hand Cam - 2.8 RSR E: 4 Bearing 49mm dia, Spray Lube, External Threads 1976-1979 F: 4 Bearing 49mm dia, Spary Lube, Internal Threads `1980 -1989 I am also keen to understand the purpose of the lug in the casting on a Left Hand 1969 911S cam - anyone know? ![]() I also have an odd set of cam housings dated 1974 and used on a 2.7 CIS engine. The housings appear to have 4 bearings 47mm dia but only 3 are drilled for the spray bar. I am confident that there are 4 journals. The cams were 3 bearing, external thread type. We took these housing off a 1974 2.7 with a K Jetronic. If we drilled out the 4th spray bar hole could we fit RSR small journal cams? I would be grateful if someone would point out the mistakes I am sure to have made.
Kartoffelkopf
Chris, can't answer the more in depth historical stuff for you, but w.r.t. that "?" in the photo, I know that on the Vauxhall cams in something like my XE "Redtop", they have very similar looking square sections, which we use simply to be able to counter-hold the cam when tightening up the pulley bolt, and also to rotate the cam when timing-up with vernier pulleys.
But that wouldn't explain why only the LH cam has this?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
andy |
Yes it does end in 1R and this is what I had hoped.
Chris
I believe the 4 bearing 47 mm journal towers are the RSR type. The 4th journal was machined, but no lube holes added, because the RSR used center lube cams. I have a couple of sets of these as well.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Max Sluiter
I think the 1977 911S had those housings with the 4th bearing that was cast but not machined.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
This is true...These were made in 76 and 77 and are the same casting as the "RSR" tower with the machined 4th bearing journal..
