El_Mecanico's Avatar
Going down that slippery slope...PLEASE HELP!!!
I dropped off my case to a reputable Porsche shop for machine work for my case. I replaced three oil squirter's but failed to apply lock tite to all three and the first attempt to peen one down I inadvertently removed to much aluminum while peening due to sharp edges of the round chisel. After removing the squirter for the second time I didn't have enough aluminum to peen since the squirter set higher than the surface area. I figured the machine shop would basically drill down further to bring the squirter further down allowing enough surface area to peen in place (my recommendation). Well today I looked at the results and I was speechless. The machine shop inserted a metal sleeve and capped it with a set screw incasing the oil squirter. And to top it off they removed 2 perfectly good oil squirter's and completed the same procedures. It looks like crap for one and I don't know how the expansion rate between the steel sleeve and the aluminum case wil react. I even passed along the info on how it should be done and provided the page from Porsche on the steps to remove and install a new oil squirter. What are my options? I believe the sleeve was inserted by drilling a bigger hole. Is this a proven fix? I figured the case needs to be sent to someone that understands our 3.2 engines. Any help would be appreciated. I willing to ship the case and have it done right. And last but not least what obligations do they have to make it right. Please help.
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 03-23-2012, 07:41 PM
AlfonsoR's Avatar
Please post a picture if you can.
"Simplicity is supreme excellence" - James Watt
Old 03-23-2012, 09:04 PM
I didnt take one.
Old 03-24-2012, 02:35 AM
I was so upset I had to leave.
Old 03-24-2012, 04:53 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Part of what we do at Supertec is restore vintage parts that are damaged by mechanical failure or brutalized previous "experts".
These disasters can at time be very expensive and unwarranted based on the ability to replace the parts but our motto is
"we can fix it, no matter how much it costs".
Humor might be misplaced considering your obvious disappointment but sometimes all you can do is smile and fix the problem rather than the blame.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-24-2012, 10:03 AM
Hi Henry,
Can you fix it then? Im willing to have it shipped if they can not find someone in Atlanta.
Andy
Old 03-24-2012, 11:57 AM
brads911sc's Avatar
Send it to Henry. you wont be disappointed.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-24-2012, 06:23 PM
