Carmagic.us
How to remove the valve spring disc 3.6L
I searched, however, I could not find anything on that. What's the best way to get the disc under the valve spring out on a 964 head. These are stuck and I don't want to destroy them.
Thanks for any help.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Schleprock
The valve spring seat/cup should be a very light slip fit into the head. Meaning, when the spring is removed from the valve, the cup should fall right out of the head if you turn it upside down.......
Kevin L '86 Carrera "Larry" |
If it is anything like a 911 head set up, they sometimes get a bit stuck with a surafce film of oil etc. try a magnetic pickup to persuade them to unstick. Works for me.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Carmagic.us
I got them out from the first head.
![]() I used a copper bar. The only place is the higher side. ![]() ![]() There was a lot of sealing compound in it. ![]() ![]() The exhaust side is more recessed and I had to use a screwdriver. Looks like I need a few new ones.
That does not look like sealer... l;ooks like funky oil crud.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
should be able to grab the lip and wiggle out any snug ones. never had your problem.
