993 Valve Lifter Question
I'm putting my 993 motor back together. I purchased new lifters. In the shop manual it says you are supposed to check the "slop" in the lifter after a valve job. You are supposed to use a lifter that has no oil in it. When I use the brand new lifters I don't have the required "slop". In fact on the exhaust side as I screw the rocker down with the cylinder at TDC (backside of the cam lobe) the valve actully opens a bit.
My question is does anyone know if the new INA lifters come preloaded with oil. If I use one of my old "collapsed" lifters I have the required play. If the new lifters are too tight will they loosen up after the engine is started? Pete |
Yes and yes. Providing that you have the appropriate lash using a non pumped up lifter.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
Thanks for the confirmation. It is kinda of freaky seeing the valve lift off of the seat when I know it should be closed.
Pete |
We have two sacrificial lifters that we use here in the shop just for measuring the lash. One for Turbo engines and one for the normals.
