MBruns for President
964 Cam Tensioners - do they fail?
How common is it for a 964 cam tensioner to fail? Have about 1800 miles on my 964 engine that received a major top end (P & C's) Cams, Heads done... When I went to restart after a first session at DE today - had a rattle that sounded like a chain tensioner.
did not replace the tensioners when the engine was out. BTW - no missed shift - no over rev - - no smoke - car runs - just sounds like chains dragging on a garbage can
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Hi,
Did you find out if it was the tensioners?
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD. |
I have seen them fail and note, there is a right and a left tensioner for proper installation.
Bruce |
Bruce, I thought both left and right carried the same part number?? I hope so because I just ordered 2!
Left and right with different part numbers.
the left side has a longer nipple on it, visually longer.
Bruce |
