MBruns for President
JeremyD's Avatar
964 Cam Tensioners - do they fail?
How common is it for a 964 cam tensioner to fail? Have about 1800 miles on my 964 engine that received a major top end (P & C's) Cams, Heads done... When I went to restart after a first session at DE today - had a rattle that sounded like a chain tensioner.
did not replace the tensioners when the engine was out.
BTW - no missed shift - no over rev - - no smoke - car runs - just sounds like chains dragging on a garbage can
Old 05-12-2012, 06:03 PM
b930's Avatar
Hi,
Did you find out if it was the tensioners?
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 05-21-2012, 03:28 AM
I have seen them fail and note, there is a right and a left tensioner for proper installation.
Bruce
Old 05-21-2012, 04:14 AM
b930's Avatar
Bruce, I thought both left and right carried the same part number?? I hope so because I just ordered 2!
Old 05-21-2012, 04:50 AM
JeremyD's Avatar
Left and right with different part numbers.
Old 05-21-2012, 04:58 AM
the left side has a longer nipple on it, visually longer.
Bruce
Old 05-21-2012, 06:28 PM
