Cams and Cam Housings
As we are just about to start machining our forged rockers and we are also looking at buying some cams and I have been trying to figure out the various types irrespective of profiles so we can sort out blanks.
I think that there were the following types:
A: 3 bearing, 47mm dia, Centre Lube, External threads. Very Early 911 and 906 ?
B: 3 Bearing, 47mm dia, Spray Lube, External Threads 65-68. 911 and may be 74 and 75 2.7 litre CIS
C: 3 Bearing, 47mm dia, Spray Lube, External Threads, MFI Drive on Left Hand
Cam, MFI Engine 1969 to 1973
D: 4 bearing, 47mm dia, Centre Lube. External Threads, MFI Drive on Left Hand
Cam - 2.8 RSR
E: 4 Bearing 49mm dia, Spray Lube, External Threads 1976-1979
F: 4 Bearing 49mm dia, Spary Lube, Internal Threads `1980 -1989
I am also keen to understand the purpose of the lug in the casting on a Left Hand 1969 911S cam - anyone know?
I also have an odd set of cam housings dated 1974 and used on a 2.7 CIS engine.
The housings appear to have 4 bearings 47mm dia but only 3 are drilled for the spray bar. I am confident that there are 4 journals.
The cams were 3 bearing, external thread type.
We took these housing off a 1974 2.7 with a K Jetronic.
If we drilled out the 4th spray bar hole could we fit RSR small journal cams?
I would be grateful if someone would point out the mistakes I am sure to have made.
Old 04-25-2012, 10:49 AM
Kartoffelkopf
Spenny_b's Avatar
Chris, can't answer the more in depth historical stuff for you, but w.r.t. that "?" in the photo, I know that on the Vauxhall cams in something like my XE "Redtop", they have very similar looking square sections, which we use simply to be able to counter-hold the cam when tightening up the pulley bolt, and also to rotate the cam when timing-up with vernier pulleys.
But that wouldn't explain why only the LH cam has this?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 04-25-2012, 04:17 PM
Does the casting number on the housings end with "1R". I think what you have there is a set of the transition housings which are neat because they can be used with early cams and also with 47mm 4-bearing cams.
andy
Old 04-25-2012, 04:21 PM
andy
Andy,
Yes it does end in 1R and this is what I had hoped.
Old 04-26-2012, 12:46 AM
Chris
I believe the 4 bearing 47 mm journal towers are the RSR type. The 4th journal was machined, but no lube holes added, because the RSR used center lube cams.
I have a couple of sets of these as well.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-26-2012, 08:16 AM
Max Sluiter
Flieger's Avatar
I think the 1977 911S had those housings with the 4th bearing that was cast but not machined.
Old 04-26-2012, 10:00 AM
This is true...These were made in 76 and 77 and are the same casting as the "RSR" tower with the machined 4th bearing journal..
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 04-26-2012, 10:09 AM
