Try not, Do or Do not
Henry Schmidt's Avatar
The best engine Porsche never built
The 2.8 short stroke is the best engine Porsche never built and we just completed our most resent iteration.
CUSTOM BUILT TO 2.8 PERFORMANCE SPECS (280 HP)
95MM JE PISTONS AND MAHLE CYLINDERS (9.5:1 compression)
3.0 TURBO ALUMINUM CASE (detail for vintage)
SHUFFLE PIN CASE
2.2 “S” CRANK (2/5 OIL MOD, MAG , MICRO POLISHED) 66mm
KNIFE EDGE CRANK FOR LIGHTNESS
D.R. BILLET CAM SHAFTS (DC 80 102 LC) good power to 8000
SUPERTEC HEAD STUDS
*NEW MAIN BEARINGS
*NEW ROD BEARINGS
*INTERMEDIATE SHAFT BEARINGS
CARRERA OIL PUMP AND PUMP MODIFICATION
NEW COMP TIMING CHAINS AND RAMPS
CARRERA TENSIONERS
SUPERTEC TENSIONER ARMS
RECONDITIONED RODS W/ NEW ARP BOLTS AND SUPERTEC NUTS
* RECONDITION ROCKERS AND SHAFTS (TEFLON BUSHINGS)
COMPLETE ENGINE BALANCE
COMPLETE VALVE JOB W MANGANESE / BRONZE GUIDES
40 MM INTAKE PORTS 38 MM EXHAUST
NEW ALTERNATOR
TAYLOR PLUG WIRES ( black)
SUPERTEC PLUG WIRE HOLDERS
SUPERTEC PLUG CONNECTOR HOLDERS
CUSTOM IGNITION HARNESS FOR 1974 CHASSIS
POWDER COATED TURBO VALVE COVERS
POWDER COATED SHEET METAL
SUPERTEC POWER PULLEY
SUPERTEC ALUMINUM FAN CENTER AND PULLEY
RSR FLYWHEEL
COMPLETE CUSTOM MFI SYSTEM (RSR spec)
W/POLYMID FUEL LINES
MFI MACHINE WORK
PMO AIR FILTERS AND 52 MM VELOCITY STACKS
SUPERTEC COLD START ENRICHMENT
RENNWERKS TWIN PLUG CONVERSION
TITANIUM SPRING RETAINERS
SUPERTEC VALVE SPRINGS
GETTY AMBER FAN SHROUD
SSI HEAT EXCHANGERS
RENNWERKS SUMP COVER
* DRY FILM LUBRICATE ALL BEARINGS
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Last edited by Henry Schmidt; 02-24-2011 at 09:01 AM.. Reason: excessive whining from Aaron
Old 02-24-2011, 07:37 AM
Champagne on Beer Budget
HelmetHead's Avatar
I wanna hear it running! Very nice work!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 02-24-2011, 07:40 AM
Henry Schmidt
Ph: 760-728-3062
Old 02-24-2011, 07:42 AM
Steve F's Avatar
Thumbs up
Pure Artwork Henry!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 02-24-2011, 07:43 AM
ALL CRATED AND READY TO GO !!
Forgotten items:
Supertec Palymid Fuel lines
Supertec MFI Pulley set
Supertec Fuel line Supports
*****For those of you paying attention: you're right. The pictures show two oil sending units. That illustrates a mid course correction. Only the rear sender was used.******
Henry Schmidt
Ph: 760-728-3062
Old 02-24-2011, 07:47 AM
Woodland Hills, CA
Absolutely a work of art. Nice work Henry.
Old 02-24-2011, 08:34 AM
Banned
Henry, nice work. Do you test bench (dyno) the engines before they go out? ,cheers.
Old 02-24-2011, 02:46 PM
356RS's Avatar
Excellent Henry as we have come use to. Dyno numbers would be great.
Mark Jung
Bend, OR
MFI Werks.com
Old 02-24-2011, 02:57 PM
We no longer dyno engines. We leave the tuning to the owner of the vehicle.
We count on the owners to select a tuner with the expertise they require.
These engines generally produce about 275 hp. The SSI and mufflers offer a bit of a tuning challenge.
With a proper size header these engines will produce close to 300hp on street gas.
Henry Schmidt
Ph: 760-728-3062
Old 02-24-2011, 04:03 PM
mca mca is offline
mca's Avatar
I want to go to there.
Purdy.
Old 02-24-2011, 05:12 PM
MBAtarga's Avatar
Great Henry!
Now that it's ready - I'm PM'ing my address to you for the shipment!
Mark
'83 SC Targa - since 5/5/2001
Old 02-24-2011, 05:27 PM
Carrerax's Avatar
Beautiful engine!! How much do you sell the degree'd pulley for? I could really use one!
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 02-25-2011, 09:29 AM
Thank you.
PORSCHE POWER PULLEY RSR 911R 911S RACING - eBay (item 250523529209 end time Mar-26-11 12:48:33 PDT)
Henry Schmidt
Ph: 760-728-3062
Old 02-25-2011, 09:35 AM
Originally Posted by 356RS View Post
....edit.... Dyno numbers would be great.
News flash, dyno numbers just came in:
"3.6 milllllllion-plus pounds of thrust" oh wait, that's the space shuttle....... sorry, move along.
Henry Schmidt
Ph: 760-728-3062
Old 02-25-2011, 09:41 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Henry....is there a reason for using the smaller oil pump?
Would the Turbo or larger style not be better...or does the pump have enough volume already?
Bob
Bob Hutson
Old 02-25-2011, 12:04 PM
The Carrera pump with the Supertec flow modification is more than adequate for the intended use of this engine (street performance).
We strive to build an engine that is appropriate for the customer so although the larger pumps as well as things like Carillo or titanium rods are included on the option sheet, we advised against over the top options.
Henry Schmidt
Ph: 760-728-3062
Old 02-25-2011, 01:37 PM
Garage dweller
Ducman's Avatar
I guess I will come out of the shadows - that is my engine that Henry just finished. It's currently crossing the country (don't anyone think of ambushing the stage coach!) It's due to arrive Tuesday and doubt I'll sleep until then. Henry has been absolutely great to work with.
Out came the 2.7 (webers, RS P&Cs, S cams, ported)
While it was out I repainted the engine bay and am generally redoing the plumbing and electrical.
Here is the car that will house Henry's creation - at least for a while
I still have quite a bit to do but really need the engine in front of me to plan the rest out - lucky for me there's still 4-5 months of winter left.
I'll post updates
Don
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 02-25-2011, 03:13 PM
Hi Don
Welcome to your thread.
It will be fun to watch this project move into the next stage.
Keep posting pictures.
Cheers
Henry Schmidt
Ph: 760-728-3062
Old 02-26-2011, 02:41 PM
Wow! Nice work Henry. Where did you get that shroud? I want one for my 3.2 SS project.
73 911T MFI Coupe, Aubergine
Old 02-26-2011, 03:36 PM
Jeff Alton's Avatar
Great looking car, getting a great looking engine!
www.turn3autosport.com
Old 02-26-2011, 08:50 PM
