DC20 Super C2 Profiles
DC20 Super C2
I have a couple of questions about these cams and would appreciate some information.
The first question is can they be ground from a standard 3.0SC cam without welding.
The second is can they be used with stock CIS Pistons without valve clearance issues if times at 2.0-2.4mm at the overlap setting.
Finally will the standard CIS deal with the increased overlap.
Old 05-17-2012, 06:12 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Chris,
I installed the Super C2 DC20 on my 3.2L engine in the '87 Carrera. Stock 9.3:1 USA pistons
The cam can indeed be reground from a SC/Carrera cam. No welding required. I had DRC do this to my '87 3.2 stock cams.
I initially timed my cams to the middle (2.2mm) of the required 2.0-2.4mm spec and did not have enough piston-to-valve clearance. I believe I had to set mine to 1.8mm lift at TDC overlap. The actual critical area for piston to valve clearance im my case was about maybe 10 degrees after TDC overlap?
I know SC pistons are slightly different than Carrera pistons, but I thought my case was worth mentioning.
Did a search and found I did share something on this before
Cam timing with DC20's
Edit......... lastly, I don't believe the DC20 has more overlap than stock. According to DRC website, the lobe separation is the same for both SC/Carrera cams and the DC20, which is 113 degree separation.
Kevin L
'86 Carrera "Larry"
Old 05-17-2012, 12:34 PM
Thank you very helpful - so there will be issues with Euro Spec 3.0 litre engines.
Old 05-18-2012, 04:37 AM
911-32's Avatar
Chris - there is a UK SC running Super C2 cams. Check on impactbumpers.com, its user BruceB. Cams may even be for sale soon. Complicated story so better to contact him direct.
Edit - not directly relevant but I am running Supercup cams (similar) in my 3.2 with std pistons. My cams came from Camgrinder
Old 05-18-2012, 08:34 AM
I have some cams that I believe are Super C2 and they are too close on the exhaust valve even when timed at 1.8mm.
I am in the process of measuring the profile as I am now doubtful of the cam grind and I am going to try to produce a model that calculates the position when the valves are nearest to the pistons so we can try to make some sensible measurements.
I think the SC piston is more of a problem than a 3.2 but once I figure it all out I will try to explain.
Thansl
Old 05-18-2012, 12:19 PM
