Oil pressure sending problem
When I'm driving along the oil pressure will read around 60psi and then I run over a bump and the gauge will drop to zero for a second or two then return to the previous reading. what causes this? Should I be looking at the sending unit on the engine or the gauge on the dash? I know if I remove the wire from the sending unit the gauge will top out with the ignition on.
Old 06-03-2012, 12:05 AM
Either the sender is going bad or the wire to the sender is grounding out somewhere. I suppose the guage could be losing power intermittantly.
-Andy
Old 06-03-2012, 02:58 PM
OK, I see removing the wire to the sender will send the gauge to the top, ground the wire it will drop to the bottom. I'll search for a grounding problem first.
Old 06-03-2012, 08:07 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Yes that mean your gauge is OK and more than likely the connector is too loose in the post.
I had to crush the connector a bit to get a tight fit and the sporadic up and down stoped
Who Will Live... Will See
Old 06-03-2012, 08:23 PM
