ASE Master Tech - 35 yrs
larrym's Avatar
Question oil cooler options - 3.2 into 914-6 ?
started my 3.2 upgrade this week - replacing a 2.7 fitted with an oem 914-6 cooler
noticed yesterday that the lower intake feed pipe of the 3.2 oil cooler is larger than my 2.7/914-6 cooler feed pipe
- so what is difference, if any, other than the obvious lack of a 90* bend inlet, ?
A> - can i just fit the older 914-6 cooler ? It appears the overall dimensions are equal
B> What are the options to convert/fit the 3.2 cooler into the 914-6 with that 90* bend issue?
C> are there any 90* fittings that can be "easily" fitted" without removing the 3.2 cooler for a welding job?
- in past I have had a -6 cooler "bend conversion" done by Otto's on a 911 cooler, so I know about that option
- i can't see any real need to go to that trouble since "originality" is not my concern and there is no apparent reason to have those -6 custom high-pressure hoses on the intake line
- there is no high pressure in that line, and the carreras used a simpler slip on hose
(I DO have a front mounted 914-6 GT Behr cooler as well)
TIA for ideas or advice
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 06-11-2012, 09:51 PM
Big difference between 3.2 and 3.6.
3.2 use -6 oil cooler
3.6 use patrick adapter fitting and huge front cooler.
but i can't see any real need to go to that trouble since "originality" is not my concern and ther is no apparent reason to have those -6 custom high-pressure hoses on the intake line -
If you dont want to use factory stuff then have a AN fitting welded onto the 3.2 cooler.
Old 06-13-2012, 09:06 AM
BoxsterGT's Avatar
Porsche Crest
larrym-
Your 914-6 oil cooler has the same physical & thermal capacity as the 3.2 engine oil cooler, and will interchange directly. Your 914-6 uses M26x1.5 threads and the original 3.2 cooler uses a 30mm push on type hose from its original 3.2 oil tank. It is the suction side into the motor.
What are the thread sizes on the GT front cooler? I can supply you with all the Metric hose & fittings you need. If they are M26, then stick with them throughout. If the front cooler fittings are M30, then I can help you with adapter fittings & hoses.
Hope this helps.
Len
Old 06-13-2012, 10:47 AM
PFM PFM is offline
PFM
PFM's Avatar
Len,
TRied to send you a PM, your mail box is full.
Stay Tuned,
PFM
Stay Tuned,
PFM
Old 06-13-2012, 07:03 PM
larrym's Avatar
super !
- thanks for the advice - it's what i need to know b4 actually pulling 'em both off to compare
mea culpa - mostly was trying to avoid it cuz it's a lot of extra disassembly on both engines to get at the top cooler nuts since i have to pull the air shroud & that means pulling all the induction & buying more new parts to re-assemble
- I will just fit my 914-6 cooler
I have two 914-6 oem coolers, one installed on the current 2.7, one in box, so it's not a $$ issue - just a time issue
my front oem GT Behr cooler is already properly attached since 1972 in Germany
but it's NICE TO KNOW someone has the metric fittings !!!!!
Old 06-13-2012, 08:08 PM
