930 cam timing question
I'm in the process of setting my cam timing on my 1985 930, I have finished the left bank, and starting the right bank. Were I get confused, were do I start the right bank in relation to crankshaft position.
This is what I understand
1. Set crankshaft at Z1 #1
2. Set both L/H and R/H cams with 930/dot facing 12:00 straight up.
3. Set #1 intake valve clearance.
4. Rotate 360 set TDC overlap.
5. Rotate 360 back to #1 TDC at Z1
At this point I'm at #1 TDC at Z1 (step 1.) Question- Were do I start the process/are position the crank for #4
Old 06-09-2012, 11:36 AM
After step 2 pin both the cams with the mark up.
4. Rotate 360 set TDC overlap on cyl 1 and #4 valves will be both closed. Set the dial indicator on #4 and rotate 360 and set #4 to desired movement.
Bruce
Old 06-09-2012, 08:00 PM
totle's Avatar
Daniel, as Bruce said. Just to clarify when you have done all above and start on right side, the mark on you camshaft will be facing down.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 06-10-2012, 12:48 PM
