FOrcerecon44
forcerecon44's Avatar
broken rocker arm ?????
i just broke my rear left side rocker arm top at aduster a clean brake !!! yes i think i overreved her ??? can it safely be jb welded or is this just a waste of time ??? if i have to remove rocker what size are the allen wrenches ?? and i can pull n reaplace it without removeing the cam ???? please advise eng pro guys thanks ??? its a 74 2.7 !!!
Old 06-24-2012, 04:05 PM
Air Medal or two
afterburn 549's Avatar
Jb will not hold that kind of pressure..and if it could you would have to have the 2 parts OIL FREE
I am thinking the broken rocker is the least of your problems...
I hope you do not have bent valves
sorry about your situation
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-24-2012, 06:29 PM
Air Medal or two
yes they can be replaced with out removing cams
Old 06-24-2012, 06:31 PM
