FOrcerecon44
broken rocker arm ?????
i just broke my rear left side rocker arm top at aduster a clean brake !!! yes i think i overreved her ??? can it safely be jb welded or is this just a waste of time ??? if i have to remove rocker what size are the allen wrenches ?? and i can pull n reaplace it without removeing the cam ???? please advise eng pro guys thanks ??? its a 74 2.7 !!!
Air Medal or two
Jb will not hold that kind of pressure..and if it could you would have to have the 2 parts OIL FREE
I am thinking the broken rocker is the least of your problems... I hope you do not have bent valves sorry about your situation
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Air Medal or two
yes they can be replaced with out removing cams
