burgermeister's Avatar
Does My Car need a Strut Tower Brace?
Dag-Nabbit, I meant to post this in the technical forum, not engine rebuilding!
Well, I re-posted it over there. No need to have it twice.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Last edited by burgermeister; 06-29-2012 at 04:58 PM.. Reason: posted in wrong forum
Old 06-26-2012, 02:16 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The answer to your question lies in the lap times you post.
From many years of setting up race cars in various classes...I can postitivly say one thing....go with what works for you..the driver!
Some drivers like "loose" cars..so they can sort of throw it around...some like "tight" cars....more presise.
The end result is in the lap times of the same car with the same driver/fuel load/weight/temperatures/time of day/and whatever.
Keep a very careful log of the changes/temps/etc...sit down at night and figure out what worked...and what did not.
I can tell you...it took 3 years to dial in a formula Ford for just one track (Mosport)...and a lot of trial and error changes.
Bob
Bob Hutson
Old 06-26-2012, 11:55 PM
Max Sluiter
Flieger's Avatar
Bob
That depends on having a driver who has reached a plateau of lap times. It sounds like burgermeister was still improving his skills with each lap he turned, therefore the lap times reflect his improvement rather than his car's.
Old 06-27-2012, 12:02 AM
HawgRyder's Avatar
You are correct sir...but remember...the feel of the car inspires confidence in the driver...so changes to the car will reflect on the lap times in both ways.
Putting a driver in an unfamiliar car with settings perfect for another driver will not always result in better lap times.
Bob
Bob Hutson
Old 06-27-2012, 09:40 AM
