Free minder
Aurel's Avatar
Well, actually it does not run anymore...but that is ignition related. I disconnected the coil to test the compression on that cylinder 3. I got 120 psi, which I think is ok considering the altitude over 5000 feet, the cr of 8.5:1 and the fact I measured it cold. When I reconnected the coil, I got no spark, no more ignition at all. Weird.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 06-24-2012, 09:42 AM
Free minder
Aurel's Avatar
Had I read a little more before doing my compression test, I would have saved myself a $89 coil...
hopefully I did not burn the CDI box too.
Old 06-25-2012, 06:44 PM
911 tweaks's Avatar
correct posting aurel...i always disconnect the 2 wires that have sm nuts holding them to the top of the coil so as to not damage coil, cdi(if applicable type car) and I unplug the coil wire out of the center top of the dizzy just to be safe...
I live for 911 tweaks...
Old 06-26-2012, 06:45 AM
Did you ever figure out what the issue was? Rod bearing, lifter, or tensioner?
Old 05-05-2019, 06:38 PM
Free minder
Aurel's Avatar
Yeah, Rod bearings. I rebuilt the whole bottom end back then...
Old 09-18-2019, 04:06 PM
Was there any metal flake in the oil?
I would think with that amount of rod knock you would find some flake in the oil.
Old 09-18-2019, 07:41 PM
