Valve guide tolerance
I just installed new valve guides in the heads for my 2.7.
If I want to check the tolerance, whats the reccomended tolerance between valvestem and valveguide?
/Nimskov
Old 06-21-2012, 04:49 AM
My Haynes manual specifies the clearance as follows: Inlet .0011 to .0059 inches (.030-.15mm). Exhaust .0019 to .0078 inches (.050-.2mm). I don't know if these are new limits or wear limits.
-Andy
Old 06-21-2012, 01:35 PM
That would be the valve adjustment clearances - not the clearance between valvestem and valveguide....
/Nimskov
Old 06-22-2012, 01:00 AM
intake .0016-.0019
exhaust .002-.0022
shoot for the high end if measuring is difficult specialty gauge pins are best used as a go no go
Old 06-22-2012, 07:10 AM
It looks like my Haynes numbers are both new spec and wear limit. They are not valve clearance numbers (that's .004 inches for both intake and exhaust).
-Andy
Old 06-22-2012, 10:21 PM
Ok, thank you very much guys!
/Nimskov
Old 06-23-2012, 02:02 AM
