911 2.5L Race Engine 89X66 10.5:1
So, since I cannot get new Mahles what alternative is their for Pistons and cylinders?
Thanks in advance.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Well right now( might change) my plan is to take 90 mm nikasil good condition or reconditioned cylinders and get JEs made to fit- not sure about 10.5/1 but probably pretty close. With all the case machining to make it 'done right'.
Did you check with Andial? They might have a set.
Bert Jayasekera 1970 911T - Tangerine Orange Early 911S Registry #494 R Gruppe #167 |
I would rather be driving
Are you in class limit where you need to be below 2500CC? If so, you need the 89mm.
If its not rule limited then you can use the 90mm 2.7 bore cylinders and get matching pistons of your favorite flavor (compression and cam clearance). I am building one as well. I am using the 90mm Nikasil cyilnders with JE pistons. This will be more a street motor compared to full race.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
up-fixing der car(ma)
I think you're allowed a 1mm overbore so you would use 90mm from 2.7 as a next good option, with high compression pistons. But if not, get Nickies 89mm cylinders/pistons, or destroke your crank to 65.4mm (custom rods or grind to 2" journal and use Pauter rods) with 90mm cylinders/pistons...
Scott Kinder kindersport @ gmail.com |
I am satisfied with Don at EBS in Reno - he helped us with a 964 cylinder recondition
and JE 102MM 12.5CR pistons. Good service and products. Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
120 HP/Liter is all I ask
Mahle does the 89 mm pistons/cylinders in batches from time to time. As already recommended, I would check with Andial on if they know when next batch is being done before going to a custom set up.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche |
