Where to buy after market cam shafts?
Was going to go with dc60 cams in my race car now I see people are having problems getting there cans from this guy. So who should I use for cams for a race car using efi? Thanks James
Schleprock
Also consider Elgin Camshafts. They are also great people to work with.
Kevin L '86 Carrera "Larry" |
When I eventually do my build I will probably also go with Web. But what do you guys think of Jerry Woods, GE cams? They seem to be popular from what I have seen here.
"Simplicity is supreme excellence" - James Watt |
Super lobes!
Dimetri Elgin has forgotten more than most know. He has the 'correct' masters for porsches. Did you know the RSR cam requires 4 masters, not two? There is actually a difference between left and right banks. Man knows his business. Elgin was JDs mentor. t
1967 912 with centerlocks… 10 years and still in pieces! |
GE 60 from Jerry Woods are great cams for a 3.0... Jerry and associates are the ones who came up with this profile to begin with. Very respected outfit.
Tell it like it is or don't tell it at all. |
What do you mean by 4 masters? Thanks
Cam lobes are very hard, so they are ground to shape. The lobe shape was machined onto a 'master'. The grinding machine then follows the master to make the cam shaft. CNC has invaded this process like every other metal working so 'masters' arent truly required anymore.
Hit YouTube, there are videos. Impressive to say the least. Anyways, most believe you can just flip an intake/exhaust pair to do the other bank. That is not correct. t
Jon |
Jim - What cams did you end up going with?
Andy - 1987 911 Carrera Coupe |
Banned
, the man know his stuff. |
Webcam........
Andy,
These are the cams Jim got for his engine: Webcam grind #: 171e/149i ![]() This is how the engine looks now sitting in my garage and awaiting for my return in late August to continue the work. ![]() Tony |
