howard freeman's Avatar
Travis, Do you still have my phone #??? Call me.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 01-28-2013, 08:10 AM
Obsessed
sobamaflyer's Avatar
Picture request - the one on the left is easily compressed by hand. On that tensioner the little disc inside is 4mm lower (at 27mm down from top of the piston) than the one on the right.
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 01-28-2013, 04:14 PM
I see they are 053's. Both are low on oil, look how low the inner disc is. Send them up & I'll fix you up.
Howard
Howard Freeman
Old 01-28-2013, 04:57 PM
Travis, Got your tensioners. Give me a call please.
Howard
Howard Freeman
Old 01-31-2013, 05:15 PM
Repaired, Going out in tomorrows mail.
Howard
Howard Freeman
Old 01-31-2013, 07:05 PM
Obsessed
You rock! And thank you so much!
'73 Mercedes 450 SL
Old 01-31-2013, 07:47 PM
The Dude abides...
bigel's Avatar
Howard, what's the magic brother? Care to share your techinque?
'03 Carrera 4S
Old 02-01-2013, 01:28 PM
Howard Freeman
Old 02-04-2013, 05:32 PM
Obsessed
Glad I asked, seems my tensioners were in pretty sorry shape. Here's the rebuilt one courtesy of Howard:
'73 Mercedes 450 SL
Old 02-05-2013, 04:43 PM
Obsessed
Next Hurdle, Rocker Arm Bushings
I noted early on that some of my exhaust rocker shafts had noticeable "wiggle" in 1 direction. I've found out this is how they tend to wear and noted below an example of what I found.
And closeup of the wear pattern and the condition of the faces.
I believe my cams and rocker faces to be in pretty good shape, plan to leave them alone. But now I have to figure out if I should change out the bushings on the worn ones.
'73 Mercedes 450 SL
Old 02-05-2013, 04:57 PM
Obsessed
This weekend saw a great amount of work done (for me anyway) but lord was it a PITA.
I didn't have the p214 tool for the tensioners, in the end it was Bruce's (Flatpac6) screwdriver method that prevailed.
And a variation of the same with a 8mm Allen and my handy 3' iron pipe.
If I have to mess with these again I'm ordering the damn tool or making it out of a strip of steel. I have 930 part number tensioners but couldn't for the life of me find where I could put a pin or a finish nail to keep the piston down.
Timing was also it's own special load of fun for my first time but I managed to keep both sides right in the middle of the 0.9-1.1mm range on my dial guage.
I got all the rockers in and valves adjusted before I wrapped her back up. Trying to stay on a roll and get this damn thing running again.
'73 Mercedes 450 SL
Old 02-10-2013, 05:45 PM
NeedSpace's Avatar
I have finally completely read through your thread....fantastic...I hope you have resolved the ticking. Couple of things:
1) Very impressed with the rebuild. I have never rebuilt a car engine (only mopeds and lawnmower engines many years ago). While my engine seems to be mostly OK, I know one day it'll happen. I was thinking of purchasing an old bug engine and having that be my first experience as it is cheaper and easier to handle and can probably carry it into my basement. Whaddya think? Did your bug experiences help you out?
2) I notice your little helper is about the same age as my little helper. Seeing him clean up with Gojo fills me with pride!
Cannot wait to hear the final video with the nice purr from this engine.
Old 02-10-2013, 09:57 PM
Obsessed
thanks!
on 1) no, after reading your own thread I'd say we have similar skill sets and general (if not trade experienced) mechanical aptitudes. Although the 1600's are similar in layout they are vastly different in practice and in tolerance, in retrospect the VW engines I tinkered with were taken down, replaced the (cheap) parts and seals and slapped back together, I didn't take (or I guess need to take?) NEARLY the effort I've put into this.
So I say no, save that $ and put it into yours when it's necessary.
'73 Mercedes 450 SL
Old 02-11-2013, 04:31 AM
Good job T. ! Get it finished so you can come to the yearly get together on March 23.
Howard
Howard Freeman
Old 02-11-2013, 09:04 PM
Obsessed
Thanks Howard - That's my goal, plan FI makes it's way back on this weekend.
'73 Mercedes 450 SL
Old 02-12-2013, 04:38 AM
Sboxin's Avatar
Thanks for the great photos and write up.
A question: did you do anything special to seal the rocker shafts?
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 02-12-2013, 06:23 AM
Obsessed
I didn't and I hope I don't live to regret it but if I do I'm not skeered to take them out and add the RSR seals. FWIW I had no leaks before I took them out and they had no seals on them.
Howard helped me determine my wear on them was pretty well within spec so I chose to leave them alone all together, but it wouldn't shock me if I'm checking and servicing them 10-15k from now.
'73 Mercedes 450 SL
Old 02-12-2013, 07:06 AM
Obsessed
Thank you Gulf Coast's strange fascination with being drunk in the street! (Mardi Gras). They partied in the pouring rain, I got closer to a finished engine.
'73 Mercedes 450 SL
Old 02-12-2013, 02:36 PM
NeedSpace's Avatar
Looking good. Love the color combo too!
Old 02-12-2013, 06:35 PM
Smoove1010
Smoove1010's Avatar
Did you spin the rocker shafts 180 degrees to put a fresh surface in position to bear the most load as I've seen other Pelicans suggest?
I agree with NeedSpace, the engine color combo looks great. The rocker covers look to be a bronze color, or is that the lighting in the photo?
GK
Old 02-13-2013, 08:08 PM
