It could be the decel valve causing the problem too. Disconnect the small line at the top & plug it. Drive the car & see if the high idle problem goes away. If that cures it let me know. I have a few used ones hanging around here & I can bring one to our car show Saturday.
Howard |
And yes, barring a washout I'll see you Saturday :) |
Well, the idle is steady at ~1700 after warm this morning w/ the decel valve & it's vacuum line plugged. note: I had to bump up the idle & mixture Sat. afternoon when I returned home so that it would re-start (gave me my 2100 rpm idle again after a short drive). Disabling the Decel has reduced the total warm idle by 400rpm or so but otherwise no change.
On another note: I went to a gas station that was supposed to have 100% gasoline, turns out they have only 89 octane in 100%. So which is better, 91 w/ 10% ethanol or 89 w/ 0% ethanol? |
| All times are GMT -8. The time now is 01:00 PM. |
