Any data I need to collect for the gurus before dropping?
After reading "what's this sound" threads for several days I've got a really bad feeling I have thrown a bearing. I have a new "knock" seems to come from the middle of the block, distinctly different from the tap that's been coming from [I think] #5 for a bit (I can't get my valve cover off due to a header that's too close to it).
I've learned/decided I need to drain and check the oil to check for fragments and I need to drop the engine anyway to address that unable to adjust valves issue. Should I make a video of the sound or do/check anything else like compression while it's still in the car and running before I start down a path that I'm sure is going to lead to quite a while without my favorite toy? As is my typical I'm on a tight budget, I know I haven't collected enough data to even ask what I could be looking at spending here. I've rebuilt 2 VW motors, will be doing everything but machine work myself. I really don't plan to try and increase performance, I'm not unhappy with it as it is. I've even lightly investigated what I'm sure is considered the highest form of sacrilege around here but I think I'd rather have you all talk me down and pray this can be fixed for some reasonable amount of $. Thank you Travis |
Try just dropping the exhaust instead of an engine drop. Then you could remove the valve covers, adjust the valves, check for broken head studs, examine the rockers, make sure the rocker shafts are centered, check springs and camshaft lobes. With the exhaust removed you can also check the exhaust ports and valves visually.
You could get your oil analyzed for signs of bearing material, cut open and examine the oil filter. Make sure to eliminate the alternator as a cause of the noise. A compression and leak down test is always a good idea to get an idea of the condition of the ring and valve sealing. Do you know much about the history of the engine? |
Thanks for the suggestion. I ordered a leakdown tester earlier so I will do that and a compression test next weekend.
Yes, please make a video with good sound to put up on this thread - the more history you can capture the better. And, a good photo of your exhaust header clearance problem might be helpful too. The mechs on this Forum can help you with that too.
Regards, |
For reference, not in my initial post:
1975 911 with a 78 (iirc) 3.0. Oil level is good (in the middle of the stick after warm), oil pressure is 30 on the gauge, warm temps never get above 200-220. I purchased it a couple of years ago, had been sitting a while, failed restoration. I got it running and have driven it 1-3 times/week since until the last month or so. Totally unknown engine history. I've probably put 7-8k miles on it, have changed the oil 3 times, last about 6 months ago and at that time tried to adjust the valves and discovered I couldn't get the right valve cover off due to hitting the aftermarket header that's on the car. Ok, videos: Initial Start - Cold: <iframe width="640" height="480" src="https://www.youtube.com/embed/36kPfznsTIU?rel=0" frameborder="0" allowfullscreen></iframe> Taken when warm: <iframe width="640" height="480" src="https://www.youtube.com/embed/epPHfxll98E?rel=0" frameborder="0" allowfullscreen></iframe> It seems my new "knock" comes on strong after a few seconds, it's steady with RPM, seems to be coming from the middle of the motor. There is a "tick" that I have undoubtedly identified to the middle right (5?!) cylinder with the long screwdriver method. All others are relatively quiet. I can't identify the exact location of my knock with the screwdriver. Pictures: This is the "diaper" under my car, haven't driven it in 3 weeks at all, as you can see it's not leaking but a drop here and there. She has never in my time consumed any oil to speak of: http://forums.pelicanparts.com/uploa...1344098542.jpg Right Bank - shows my clearance issue w/ the header: http://forums.pelicanparts.com/uploa...1344098683.jpg Right side showing cam cover: http://forums.pelicanparts.com/uploa...1344098718.jpg Bottom of the engine: http://forums.pelicanparts.com/uploa...1344098773.jpg Left Bank - this side clears the header http://forums.pelicanparts.com/uploa...1344098833.jpg Left Cam: http://forums.pelicanparts.com/uploa...1344098888.jpg |
Very good on the videos and photos!
Valve covers: looks like the right exhaust has to come off one way or another to inspect the rockers and adjustment. Knocks and taping : You will need to get a really good ear to listen to the video - Grady Clay, Henry Schmidt, Bruce Abbott(Flat6pac), etc. -- suggest PM them to get their attention... and cross post a link to this thread on "911 Technical" My guess on the knock is like yours' -- rod bearing failure. If you drop the engine now you can do a top end and check the rod bearings - if #5 looks like ours did then you will need to open the case and polish the crankshaft anyway. It seems you are prepared to do what is necessary to keep this really nice Porsche running for yourself. It also appears some previous owner modified the car for a Hot Rod - and may have driven it too hard or run the engine hot at some time in the past. The main bearings seem to last forever but the rod bearings take a beating. Be prepared to replace a lot of parts you might not have thought about when you open this engine up -- and they ain't cheap. Be sure to get a machine shop to measure cylinders and everything you take apart...Porsche has very low tolerances (we found out the hard way - thought we could do rings and bearings, now looking at big $$$$- BUT, we are also building a race engine- "since you are in there") Wish you the best, Regards, |
Cross posted to 911 Technical with a very good Grady Gray response --
http://forums.pelicanparts.com/porsche-911-technical-forum/692592-cross-post-another-whats-noise-thread.html I hope you follow Grady's instructions... Regards, |
I fully intend on it, embarking on the path next weekend (this weekend's shot due to work and I want to do that leakdown test)
Noise detection.......
Travis,
Have you tried to use a mechanic's stethoscope? It not easy to determine where and what was the noise from your videos. I have seen and worked on a motor that the owner thought was a bad motor. And it turned out to be an improperly adjusted intake and exhaust valves. Have a second opinion from someone familiar with 911 engines. Tony |
Thanks Tony, I'll keep every appendage I have crossed in hopes you are right! I know for a fact they are a bit out of adjustment. I will know more this weekend and will report back with my findings.
I don't have a mechanic's stethoscope but I did spend some time with the longest phillips head I have crammed in my ear :) |
Turning it back to the engine rebuild forum
I've been updating my other thread but not getting a lot of direction out of it so I'd like to turn it back here since this has fully become an engine rebuild:
Posted 10/2/12: Made a little more progress today (a little) I have the top stripped down, chain covers off, cam nuts are both loose. I continue to feel like this engine was rebuilt not terribly long before it was put away, everything inside is relatively spotless, seals are all fairly fresh. I don't seem to have Carrera tensioners but they look odd (anodized collars on the top?), any hints as to why they look different than what I've seen in pictures? I have the valve spring compressors on-hand but have yet to delve into exactly how to use them. I'm continuing to follow the book so... http://forums.pelicanparts.com/uploa...1349220629.jpg http://forums.pelicanparts.com/uploa...1349220640.jpg |
Posted 10/14/12:
I'm looking for those in the know to comment on what I've found so far. Clutch: I'm in need of a new disc? Resurface the mating surface or can I clean it w/ a scotchbrite pad? http://forums.pelicanparts.com/uploa...1350237312.jpg http://forums.pelicanparts.com/uploa...1350237445.jpg Cylinders: All look like this, some carbon buildup on the crowns but the cylinders seem to be in nice smooth shape. Given my good leakdown and compression numbers I'm thinking about removing the pistons & cylinders as a unit (as described in the book). Not messing with them/the rings? http://forums.pelicanparts.com/uploa...1350237711.jpg http://forums.pelicanparts.com/uploa...1350237744.jpg Heads: Also (aside from dirty) appear to my untrained eye in decent shape (I may be corrected in this) the valves appear to seat but I need to look into this further. I also still need to take off the valve springs to check them and see if one is broken. I foolishly bought the 2 seperate tools when I needed the 1 big c-clamp one. http://forums.pelicanparts.com/uploa...1350237800.jpg Studs: I'm thrilled! Every single dad-blame nut came off without incident. Hoping someone can tell me what is here, they are not magnetic, they are black and slimmer in the middle than the threads. http://forums.pelicanparts.com/uploa...1350238073.jpg I continue to hypothesize that this engine was rebuilt some time before it sat for at least a few years. I have no basis for judgement of the quality of the rebuild, what was done, what wasn't. I highly doubt this is a stock, original '78 3.0. I still have a way to go, I plan to at least get all the way inside to find out if there is a bearing messed up causing that knock. (I will be at a loss if I find nothing amiss as I have so far) Thoughts, opinions, tips, hold on moron what are you doing??(s) Thanks, Travis |
Posted 10/16/12:
I really thought I'd find something significant at this point...... Trying to capture the amount of play I found on the rods. This is indicative of all 8, I can wiggle them side to side less than a mm. <object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/CBD1W0WxpHo?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/CBD1W0WxpHo?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object> (pardon my shop helper in the background) Pistons: All look exactly the same, all rings visually appear clean, solid, ok. Surfacing is clean, mar free. http://forums.pelicanparts.com/uploa...1350429870.jpg http://forums.pelicanparts.com/uploa...1350429881.jpg http://forums.pelicanparts.com/uploa...1350429895.jpg http://forums.pelicanparts.com/uploa...1350430057.jpg http://forums.pelicanparts.com/uploa...1350430075.jpg http://forums.pelicanparts.com/uploa...1350430087.jpg Dennis, I tested my rocker arms for play, when off the cam I can wiggle them maybe 0.25mm back and forth (all of them) So where do I stand? Do I keep going since I'm this far? Do I finish taking it apart the case? Shouldn't a failed bearing have presented itself at this point? Or maybe that was never the cause of my disturbing knocking (and if not what was?) Hoping someone will tell me check this or that or notice anything good or bad in my photos. I'm in too far to just put this back together without ensuring (to some measure) that I will get some significant mileage out of her before doing this again, but I also don't want to waste $ if it is fine. |
Compare your rod play between each other especially in and out of the engine because youre high on the pressure at the top of the stroke.
Someone has been in the top of the engine because you have 24 dilivar studs, there is no appearance of a broken vlave spring from hitting the piston. I did about 20 years ago have an engine that sounded like piston slap and it turned out to be bad rockers..after I bought a set of pistons... Youre far enough down you might as well reseal the case. That will tell you about the crank and reseal the center line of the case after cleaning everything up. Youre already committed to a certain amount of expense and unless you look at everything youre shorting yourself as to know what you own.. Bruce |
Thanks Bruce, you are the second to suggest I may have rocker issue. I was given the number of a machinist with old Porsche experience today to call today and after talking to him for a good while I'm taking my heads to him Monday. He is going to disassemble them and check everything for spec. Also taking him my p & c s tomeasure and check out.
I intend to finish opening up the case as I do want to know full well the state of everything and I'm this far... I'm glad someone else thinks this engine has been into, the studs are my biggest clue, they look brand new, as do many reciprocating parts. My problem is I don't have a way to feel convinced what parts I don't need to replace. Hoping this machinist will help me in that evaluation. Can't afford to just summarily replace everything that is fine. sent from my Galaxy S III |
Your head studs were already updated, so that is one less thing on the to do list. Did you try to adjust the valves before taking the engine appart? (Although I would agree it sounded more than just valvetrain noise...).
I had adjusted them about 6 months before the new noise. One of the several reasons I went ahead and pulled it was that I couldn't get the right lower valve cover off due to header clearance.
...I now know I can loosen said header enough to get it off while it's in the car. :-) sent from my Galaxy S III |
Have you checked for any abnormal lateral play in the rods? A rod bearing failure might knock like that.
I'm going to open it up to be positive. But I have taken each one and tried to push and pull and don't have any play in and out in them at all.
Your cylinders are alucil so there is nothing you can do with them, even measured, you have to keep everything together.
Bruce |
Is that a problem? Do I need to re-ring or is there a set of measurements to find out if the ones I have are good
Flip a coin, feeling lucky? Many including myself have successfully installed new rings in Alusil cylinders. From all the informaton I've read it's a 50/50 proposition. With 81,000 miles on my car, I took the chance and won. They seated well and no problems 3000 miles later. Your mileage may vary! |
Interesting, I didn't realize this was a oil-esc hot button issue but a brief search suggests it is or was.
Am I being myopic in thinking my compression and leakdown #'s suggest the rings are sealing well and I should leave them alone? I'd like to know how to tell for sure but I wonder if they were already replaced when those head studs were. |
Check the top ring land and put them back together again, remember, youre looking for the click in the engine..
Bruce |
Thanks Bruce, good point!
checking for excess room on top landing as if it's been stretched correct? |
Unless they have been abused, theyre usually OK, Point being youre not looking for a rebuild but to get it back on the street.
But it does pay to know what you have.. Bruce |
I only replaced my rings due to one ring breaking during removal for cleaning and measuring. Being a little OCD I replaced them all... Onwards to the cause of the ticking....:D |
Maybe I'm getting somewhere
I too think given all considerations my rings/pistons/cylinders are getting put back just like they were, they weren't "broke"... :)
So I dissassembled the rockers this morning in preparation to take the heads to the machinist Monday to evaluate the valves. I did find a broken outer spring, oddly it was on the opposite side of the engine to where I think the noise was. Here is the #2 Intake spring: http://forums.pelicanparts.com/uploa...1350753845.jpg I found 3 shafts with a small amount of play in them (video below demonstrating). The remaining 9 were all smoothly rotating but snug. I notice the play is back and forth only as if it has ovalled the bearing (i.e. it was snug in the y axis and would wiggle in the x axis). The loose ones were 1 & 3 Exhaust and 6 Intake. <object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/m8YuyntPvPM?version=3&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/m8YuyntPvPM?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object> Here are photos of 2 of the shafts with play in them. http://forums.pelicanparts.com/uploa...1350754125.jpg http://forums.pelicanparts.com/uploa...1350754141.jpg Finally the Camshaft(s), both look equal to the demonstration photo. I don't find pitting or scoring on any lobe or main of either. http://forums.pelicanparts.com/uploa...1350754265.jpg http://forums.pelicanparts.com/uploa...1350754278.jpg thoughts? |
Your video is private so I can't watch you wiggle!... :)
LOL, see if you can see me wiggle now
Yep, yer wiggles been watched!
Time to re-bush those rockers. Cgar did mine, but he hasn't posted here since July. I sent him an e-mail today. Check these posts out: Pelican Parts Technical BBS - Search Results |
Do I need to rebush all or just the ones with play? And I assume the collective wisdom is going to say replace all the springs?
I submit for evaluation: http://forums.pelicanparts.com/uploa...1350823549.jpg http://forums.pelicanparts.com/uploa...1350823569.jpg http://forums.pelicanparts.com/uploa...1350823586.jpg http://forums.pelicanparts.com/uploa...1350823604.jpg http://forums.pelicanparts.com/uploa...1350823626.jpg http://forums.pelicanparts.com/uploa...1350823648.jpg I couldn't find a speck wrong inside the case, everything is tight and shiny. All the mains are clean with a overall grey-ish color (not scored or worn). They have 930 part numbers on the back. I took the crank out and rechecked all the rods, there is no play in and out on any of them. I'm thinking I'm not going to take them off? All the rubber seals look brand new. So what do I replace in here, I assume that new looking or not I need to get the full engine re-seal kit and replace all the o-rings and such? The seal at the flywheel is pretty and white and hadn't a trace of leakage, replace it anyway? I'm not going to cheap out here, I don't want to be this far into my engine again for a long long time so?? For the record I don't regret doing this a bit, I had a totally unknown quantity and was at least a little nervous a lot of the time wondering if something was going to disintegrate in my 34 year old engine. Now I will happily set off into the wild blue yonder knowing it's solid and fresh and will get me home. That said have I proven my issues that started this journey must be up in the valve-train? |
Welllll....
Just to add a little data to your bank... Our 964 crank main bearings looked like that too - pretty nice.... However, when we removed the rods one looked like this... probably overheated, low oil, etc...engine history unknown - but running when removed http://forums.pelicanparts.com/uploa...1350854650.jpg http://forums.pelicanparts.com/uploa...1350854681.jpg This is the crank main bearings -- all good -- but we replaced them all anyway... and measured, magnafluxed and polished the crank I would suggest removing the rods just to be sure -- and then replace the rod bolts with ARP -- we went a step further and had the rods reconditioned (they remove some of the flat part of the rod and cut a new round big hole - and replace the bushings - like new when finished) A bit of while you are in there. http://forums.pelicanparts.com/uploa...1350854846.jpg Regards, |
If it were me, I'd re-bush all the rockers and probably replace all the shafts. The springs would be on my list as well.
Sent you a PM. |
Yep, a full set of springs are on my list.
Dropped the heads off at the machinist yesterday, awaiting a report on if I need guides or a valve job to go w/ my new springs. |
Oil in the intake
Quick question, how much oil is "normal" to be found in the intake system (inner box, intake manifold pipes, AAR (or is that AAV?...bolted to #5 runner). everything from the air plate to the throttle body to the pipes has a wet coat, it poured out of the AAX.
Remember the oil system is sealed with the vapors going directly to the top boot between air flow sensor and the throttle body. To have oil in that area would be a given. The oil condences leaving the tank and being sucked into the engine. There is no mix of fuel until the bottom of the aluminum tubing at the head to cut the oil.
Unless you have run too much oil in the tank with expansion from heat you have natural accumulation. Bruce |
Thanks Bruce, thought so but I was making sure.
In the photos of the pistons and cylinders, am I mistaken in reading "MAHLE" on the inside of the piston skirt? Are you guys sure those aren't Nikasil Mahles' but rather Alusil KS components?
He also reported a 2nd broken valve spring, several exhaust (only) valve guides out of spec and of course a few of the rocker bushings out. The shafts were all fine, the valves and seats were all good. I've already purchased 12 new bushings and a whole new set of springs. I'll be ordering all new exhaust guides and a new set of valve stem seals (at his request) Monday. I'm at the bottom of the hill, starting my way back up :) http://forums.pelicanparts.com/uploa...1352670898.jpg http://forums.pelicanparts.com/uploa...1352670924.jpg http://forums.pelicanparts.com/uploa...1352670950.jpg |
| All times are GMT -8. The time now is 08:18 AM. |
