Banned
Twin Plug drill
I want to drill my 3.2 heads to twin plug, any one has diagram or recommend factory?
Many thanks!
Old 08-09-2012, 10:34 AM
Champagne on Beer Budget
HelmetHead's Avatar
I would suggest leaving this modification to a competent machine shop that has done this before. (unless your a machinist that has milling equipment available for this type of work).
The going rate for twin plugging your heads is around 500-700 USD including the lower valve covers.
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-09-2012, 01:39 PM
brads911sc's Avatar
I agree. Unless you want to buy a new head. I dont doubt that you could do a few without error, but doubt that you can do six. unless your a machinist...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 08-09-2012, 04:36 PM
Banned
Thanks HelmetHead and brads911sc
do you have any recommend shop?
Old 08-09-2012, 06:56 PM
Cylinder Head Specialist
xtremech's Avatar
A set of disassembled / clean set of heads should cost around 350.00-400.00. Definitely not a job to learn as a 'one off. Very difficult task
Bill DiCondina
Xtreme Cylinder Heads
772-286-1660
http://www.xtremecylinderheads.com
xch@bellsouth.net
Old 08-09-2012, 08:24 PM
HelmetHead's Avatar
Depends where you are...heads are pretty heavy to ship (you really should build a wooden crate and carefully package them) so I'd look for a regional shop to work with. Contact William Knight at Knightrace dot com and he can help to recommend a shop
Einar
Old 08-10-2012, 06:17 AM
xtremech's Avatar
Home depot has plastic containers that fit 6 heads perfectly. They will be 55 lbs in a 22x16x12 crate. UPS charges extra for the plastic crate, Fed X does not. Should be around 50.00 to ship ground anywhere in the states.
Bill DiCondina
772-286-1660
xch@bellsouth.net
Old 08-10-2012, 06:24 AM
tadd's Avatar
twin plugging
There are some old threads on this. I have done it right first time out. If you are comfortable with a manual mill, then you can do this if you take the time. I made two simple pieces of tooling to do the alignment.
The only cavat to watch for is that a standard 'off the shelf' tap is not good enough since the tap class is too sloppy. I would suggest a tighter class bought on heres interwebs , or better yet, going slightly undersize and follow with a roll tap to final size. Cgarr has a post on this when he educated me.
First time around took me about 8 hrs to do six with the very first setup running about 3-4 hours feeling it out how I wanted to do it.
I made a plate spiggoted to the cylinder seat that bolted the head down. Then I made a rod that was threaded for the standard plug (14x1 mm IIRC) and 3/4" on the other end to fit a standard R8 collet. I then 'floated' the head/base plate unit on the rod and adjusted the bridgeport head so that the plate was square and resting on the table. Clamp into postion. Remove rod, zero indicators. Now you need to unbolt the head and rotate 180* and rebolt. Now this is the kicker, the hole will be in the wrong spot since its a true mirror image (not a C2 rotation), so you need to translate the table. I forget the amount. Its in pelican somewhere. I had 27-28* angle on the head after bolting down just for reference. With a 3/4" end mill just touching the top of the head, youll need to plunge 2.4" deep. Then switch to a 7/8" end mill. This cut is 0.35-0.40 off the bottom so figure 2-2.04" deep. The 3/4" cutter will give your final seat for the plug crush washer so youll need to 'eyeball' out that final ~2.4" so that you have a clean, unbroken seat (you are cutting fins).
Speaking of fins, I used canning wax that i beat between the fins to support them so they didnt break while cutting. Used a rubber mallet. Scrapes out later with a probe. I have also seen the fins just machined away so you dont even have to worry about them at all.
Finish with the correct drill bits/taps.
When done use the rod from the back side of your new hole and with a standard vice, clamp at whatever wierd angle it is, then go in with a 5/8" ball end mill to cut the plug pocket within the combustion chamber.
Thats all there is to it. Spend $50 get a junk head and give it a whirl.
t
1967 912 with centerlocks… 10 years and still in pieces!
Old 08-10-2012, 11:04 AM
brads911sc's Avatar
where you located?
Old 08-11-2012, 08:29 PM
Just got my 3.0 heads drilled for twin plugs, ported with a valve job by Ollie's. Probably the most experienced Porsche machine shop in the country. They came looking like a peace of art. Perfect.
Old 08-12-2012, 06:24 PM
HelmetHead's Avatar
t
This is what I love about Pelican! It might not be an easy project but somebody has done it and is willing to share their experiences ....Nice write-up T!
Einar
Old 08-13-2012, 06:16 AM
Banned
Thanks for your guys info, I am in Taiwan, I have to ask my brother carry it when he back to NY.
I saw the write up, I will translate it to my machine shop, see what they can do.
But I think I will send it to State.
Old 08-13-2012, 09:43 AM
