How to ID 3 liter pistons
I think the 3 liter engine came with 8.5, 9.3, and 9.8 compression ratios. How can I identify which pistons are which? Thanks for your help.
Tom
1972 911T (with 3.2), 1985 930-EFI Conversion (in progress), 2016 Cayman GT4
Old 08-13-2012, 08:46 PM
Tom
There is a casting or forging number underneath the dome. Use this chart to match the number with the piston type.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-14-2012, 02:35 AM
Thank you very much for the information. That is what I needed to know.
Tom
Old 08-14-2012, 05:41 AM
Walt Fricke's Avatar
Tom racing:
So the Euro and US 3.2 Mahles have the same casting? The US version just has what - more machining on its combustion surface to remove some metal and lower the CR?
This is of a distinct avocational interest to me, because at some point I can get my borescope up in there on an assembled engine through the oil return tubes. But if it is not worth trying on a 3,2 I won't. I'll have to rely on that the piston top looks like..
Old 08-14-2012, 06:31 PM
Walt
This should help.....
Help - Identifying 3.2 Carrera Pistons
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 08-14-2012, 06:42 PM
Oh, well. I can always just measure compression with the Whistler. I can tell if they are Mahle's with the borescope down the plug hole before checking CR to see which they are.
Old 08-14-2012, 11:06 PM
Vin-barrett's Avatar
8.5 early 3.0 CIS is easy to tell because they are completely flat on one side
9.3 and 9.8 are similar looking in that 9.3 has a dip in the crown and 9.8 is flat
see here for the difference
are these euro pistons?
-Vinny
1983 911SC
Old 08-17-2012, 09:52 AM
Found pics
Here you go
-Vinny
1983 911SC
Old 08-17-2012, 10:01 AM
Thanks, Vinny
Great pictures and captions.
Walt
Old 08-17-2012, 12:43 PM
