Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
What to build from collection of 2.0-2.2-2.7 parts.
Over the last two years I have come to own several long blocks and other various parts in prep for building a motor for my long hood project. Car is to be used for weekend mountain and occasional track events. Mag case 915 trans with 7:31 will be used. Inventory thus far is:
A virgin 1968 L 2.0 long block, with 1R case
A rebuilt 2.2 long block, w 2R case. Pistons and cylinders unknown yet, haven't opened it up.
2.7 crank, rods, heads and cam towers
3.2 oil pump
Weber 40's and various manifolds
First thoughts are to build a 2.4, but I would like to hear some opinions on options, and I know there should several available
Thanks!
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 09-10-2012, 06:50 AM
I just built a JE 2.8, 9.5 and Solex cams on a 74 case, CIS S heads for port size. Driver says it pulls great. with the modified PMOs to match.
Bruce
Old 09-10-2012, 10:47 AM
long hood moto options
Depends on money, duh. you don't say what year of long hood. If you care to keep period correct size, put a two liter together for a 69 or earlier 2.2 for 70 71, 2.3 for 72 or 73. If you don't care on size correction (I don't by the way) engine size does matter. with the exception that a 66 crank thats counter weighted with good heads cams etc that you can wind it a bunch would be cool. If you have the cw crank how about 95 mm pistons 9.5 JEs and your 40 webbers, 35 or 36 mm heads L cam which is the same as an E for a revy 2.5. SSI and early exhaust. Good for 180 or 190 crank hp or how about a 2.7 with 9.5 pistons 2.7 crank your L cams or bigger same exhaust. now were talking 200 to 220 crank hp. I had similiar bunch of parts as you but no cw crank so chose the above 2.7, now waiting for the finished motor. best Henry
Old 09-10-2012, 02:39 PM
Stahlwerks.com
jhelgesen's Avatar
Long hood project is going to stay a narrow body, R type lightweight. Don't have unlimited funds. I like the idea of the high revving 2.5.
I need to do more research as to what the "L" is.
Up in the air the most to me is piston and cylinder options.
John Helgesen
Old 09-10-2012, 04:46 PM
Stahlwerks.com
jhelgesen's Avatar
So far two directions, long stroke 2.4, or short stroke 2.5.....
Old 09-14-2012, 08:42 AM
djpateman's Avatar
What is the serial and build # on the 1968 case, then I can tell what type it is.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 09-14-2012, 06:03 PM
Stahlwerks.com
jhelgesen's Avatar
It's a 68 L long block! I'll look up the number
John Helgesen
Old 09-14-2012, 06:23 PM
Stahlwerks.com
jhelgesen's Avatar
Numbers are
3281463
901/14
15843
John Helgesen
Old 09-15-2012, 04:37 PM
