Wer bremst verliert
JohnJL's Avatar
Engine #6135776 lookup please
I have this engine on a stand and interested in its original donor. Could someone provide a lookup please?
It looks to be a 2.7 case with big bore intake heads, carrera tensioners and webers but there are lots of mixed bits on the car it came from.
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-05-2012, 09:32 PM
Wer bremst verliert
JohnJL's Avatar
Heads are 38mm intakes, listed in Bruce's book for 906 and 911R racing engines, 911/20, 911/21, 911/22 for "racing engines fuel injected" and "racing engines Weber 46IDA carbs".
Old 10-05-2012, 10:05 PM
E Sully's Avatar
My 1973 2.4 cis engine number is 6135865. Yours seems to be a little earlier. What is the other number stamped by the cylinder, mine is 911/91.
Ed
1973.5 T
Old 10-06-2012, 04:50 AM
John
That S/N corresponds to a 1973.5 911T. This would have a 7R case like the 2.7 but with smaller spigots for the 84 mm cylinders. The stock configuration would have the unique 2.4 CIS heads with an injector hole and the 30/33 mm ports
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-06-2012, 12:06 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Ed and Tom. The PO represented the motor as a "2.7 built to RS specs." Its another Pelican, but the statute of limitations is up so I wont name names unless he wants to pipe up.
I need to finish stripping the rest of the car now and get a big order into Pelican ASAP so just trying to guess what motor bits I'll need before actually tearing it down. It ran fine before but I still plan on rebuilding it over the winter.
So, a 2.4 case with what is reported to be 2.7 jugs and mahle pistons and S cams....it was fun when it ran, lets see whats going on inside...
Old 10-06-2012, 03:05 PM
John
The 2.4 case can be opened up at the spigot bores to accept the 2.7 cylinders. With those big ports, the engine is obviously not stock.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 10-06-2012, 07:12 PM
