Wer bremst verliert
JohnJL's Avatar
Sprocket stuck on cam
Hi Guys,
I've got a problem I've not run into before. The sprocket is stuck on the left side cam. I've trued gently prying but I dont want to damage the chain cover or the sprocket. I've tried freeze spray, and tried turning the engine over a few times while attempting to hold the cam still.
Is there a trick to getting a stuck cam strocket off the cam?
Thanks!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-27-2012, 03:15 PM
Try this method........
John,
Have you tried heating the sprocket? Penetrating oil and heat cycle would help. If it is really tight and stubborn, I would use a two or three-arm gear puller. But do not force it. With the puller installed, use heat and penetrating oil in conjunction with light tapping force applied on the sprocket face. Keep us posted.
Tony
Old 10-27-2012, 04:09 PM
E Sully's Avatar
Make sure the key, shown by arrow, is sitting properly and not preventing the sprocket from sliding off.
Ed
1973.5 T
Old 10-28-2012, 05:40 AM
Wer bremst verliert
JohnJL's Avatar
Thanks guys.
Ed, I mean the chain sprocket itself, before getting to the step you show above. Though I have forgotten that step before.
Old 10-28-2012, 06:57 AM
I've run into this one before. Tough to grip it especially with the chain on the sprocket.
I have found that gently prying and wiggling it from side to side, usually will free it up. You may need to tap it back onto the cam a little until it will wiggle especially if you have it jammed up. Make sure you remove the timing pin before removal.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-28-2012, 08:55 AM
KTL KTL is online now
Schleprock
KTL's Avatar
If you have a small two jaw gear puller, that'll get it off. You can insert the end bolt (if it's a bolt-end cam) as a bearing surface for the jacking screw. You're not putting a lot of force on either the sprocket, or the bolt, so its not a big deal to pull with the puller. Since the confines are rather tight, you're really just holding the puller in place to get a half decent grip on the sprocket. Light turning of the jack screw is all that's needed to pull it off.
Kevin L
'86 Carrera "Larry"
Old 10-29-2012, 08:24 AM
