Snarling beast! Freakin' awesome.
'90C4 |
Schleprock
Watch your oil level now that you've got it running. Your level that is showing 1/2 way on the stick when dead cold can jump up A LOT when the engine gets up to operating temperature. I recently overfilled my '87 that was up on blocks for way too long. Turns out I hadn't drained the engine sump before refilling with fresh oil. The James Bond 007 Aston Martin smokescreen I laid down in my neighborhood was downright SHOCKING. So much smoke in my garage that I couldn't see more than 3 ft. in front of my face. Now I know what it feels like to be a firefighter in the the thick of a smoky fire.....
Keep that idle speed up while you're running the car parked. You want to get plenty of oil to your cams and rockers if they're new or reconditioned.
Kevin L '86 Carrera "Larry" |
