pilot bearing question
i have a 78 3.0 motor that i rebuilt and am buttoning everything up. I went to install the pilot bearing, and on my 82 motor, the bolts are M8 (I think), the threads on the crank on this 78 are M4 (verified with a tap). I know that I have used this motor, and the only flywheels I have are all set up for the 3 bolt pilot bearing (instead of the press fit). I know that I did not ever have a press fit flywheel ( i have 3, a lightweight, and 2 stock ones) pilot bearing. I'm stumped. I could use m4 bolts with washers, but there would be a hell of alot of play and I figure the bolts would just shear off if the bearing moves (even thought its a tight fit in the flywheel itself), i could drill out the current holes to M8's (or what ever the proper size is) but i don't like that idea, as I'm not sure that would work properly, or i could machine some aluminum spacers to fill in the m8 to m4 bolts and go that way... anyone have any idea what I have here. The flywheels all bolt up properly, and there is the small protrusion in the center where the pilot bearing would sit flush with the flywheel.
Old 11-25-2012, 12:58 PM
The 78/79 is the press fit on the flywheel
The 80 to 86 uses 3 6mm cap bolts, 5 allen
78/79 crank
80+ crank
Flywheel and pilot 78/79
Bruce
I grew up in your country, 6 miles N of Esperance off rt 30
Old 11-25-2012, 02:17 PM
bruce.. thanks.. i just can;t explain why there are 3 M4 threaded holes in the crank, and I know that i used one of the flywheels i have on it when i had it in the car.. oh well, i'll just buy a new lightweight flywheel and pilot bearing from our host so i have the right things.
Cool that you grew up near Esperance. We got our first snow fall this year today, nthing much but still its a start.
Old 11-25-2012, 04:04 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Wink
the holes in crank are for a different pilot bearing & flywheel setup -
. 915 type FW for 3.2 crank - you can read the FW number in picture
. pilot brg for that 915 setup
. later G50 style
. Pelican sells all of the types - i recently got them both from here
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 12-01-2012, 12:29 PM
My pictures are correct. The "915 setup" is only correct for 80 to 83 SC.
Bruce
Old 12-01-2012, 03:00 PM
PFM PFM is offline
PFM
PFM's Avatar
Bruce,
So I have a 3.0 Euro, 77-78, so uses a 2.7 crank. I am building this for a 914 application what pilot bearing is used for this application? 914 / 6 flywheel not a flat 911 flywheel, 901 trans.
Thanks in advance,
PFM
Stay Tuned,
PFM
Old 12-01-2012, 04:05 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
One of the oldest tricks to remove an old pilot bearing....fill inside of bearing and flywheel with grease...drive in a wooden or metal shaft of the slide in tightest fit you can find...and the hydraulic pressure will pop out the old bearing in no time at all.
Have fun.
Bob
Bob Hutson
Old 12-01-2012, 05:53 PM
