head studs on a 73 911E
I have recently begun the dissassembly process on my 73 911E project car.
I have the engine stripped down to the pistons. The head studs are all in tact
and everything appears original to the car. Should the studs still be replaced? If so,
which studs would be best for a relatively stock configured engine?
Thanks,
Bill
Old 12-19-2012, 04:36 AM
Bill
Your steel studs will be fine as long as there is no significant corrosion on them. Standard practice for a rebuild is to remove them and have case savers installed before reinstalling them.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-19-2012, 05:57 AM
73 911E head studs
Thanks Tom
Are the case savers used to prevent the studs from pulling in the future even though the studs seem to be intact properly at this time?
Bill
Old 12-19-2012, 09:45 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Magnesium cases are not as strong as aluminum...so case savers will distribute the load of the studs better.
It's one of those things that is relatively cheap to do while the engine is apart...and expensive when the engine is all together in the car and a stud pulls.
Bob
Bob Hutson
Old 12-19-2012, 09:54 AM
The stud shouldnt pull out of a 2.4 as there is no aluminum expansion as in a 2.7.
Bruce
Old 12-19-2012, 10:16 AM
