j911brick's Avatar
Originally Posted by Walt Fricke View Post
I am pretty sure Calico does not manufacture bearings. They are a coating company (and a good one). Last I dealt with them - a couple of years ago - I remember that they could get you quick turn around if you sent them new bearings in the box, as they had already coated a number of bearings often requested by customers. So your new ones were more like a core charge. Doesn't surprise me if they decided they could also just sell new ones they coated directly - though taking something for their trouble, costs, and risks out of the deal beyond just the coating and their supplier's charges to them.
I was thinking the same thing.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-18-2012, 11:20 AM
I am building a 3.0 l SC motor and could use some assistance.
Could someone please confirm the part# for the GT3 Main Bearings? The number mentioned above does not come up with the correct part for me?
Also I would like a part# for the GT3 Rod bearings
John
Old 01-31-2013, 09:07 AM
120 HP/Liter is all I ask
What is the deal with the colors on the GT3 crankshaft and main bearing sizes?
Porsche Motorsport lists 3 part numbers for 2004 GT3 #2-7 mains: 996.101.232.91 as well as numbers ending in a .92 and a .93
The .91 is for a Red marked crankshaft, .92 for a Yellow marked crankshaft and .93 for a Blue marked crankshaft.
The #1 bearing has a similar number/color scheme as well. 996.101.231.91 & .92 &. 93 for Red, Yellow, Blue cranks respectively
The Porsche street catalog only lists the .92 bearings for the #1 to #7 bearings, not the others.
Con rod bearings are 996.103.121.94 with no color references and is the same number in both street and motorsport books.
The #8 is the same old 964.101.138.01 number we know and love.
What is all this about?
Also, if one had in hand a fresh set of the Glyco bubble packed bearings that look very nice, would you go Porsche Motorsport bearings anyway with a GT3 crank?
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 02-10-2013, 02:08 PM
Talking to Don at EBS, it seems that Porsche divides the GT3 crankshafts into size groups as they do cylinder groups and the bearing selections are for tighter control of the clearances.
My theory is that after production QC check that more cranks come out "nominal" in the middle = the yellow cranks and thus end up in street engines and the red and blue marked cranks are the plus and minus from nominal dimension cranks that are fewer in number and therefore go into the race engines and why only the .92 bearings are available from dealers.
Old 02-11-2013, 03:30 PM
So do we need red / yellow or blue for a street 89 930?
Old 11-28-2013, 11:25 AM
What is the difference in measurements between Yellow,blue or red?
will these GT3 bearings fit a 1986 3.2 mains?
Old 05-08-2014, 06:14 AM
AlfonsoR's Avatar
I cannot locate thread tools on my iphone, sorry.
Old 09-05-2014, 09:44 AM
Originally Posted by sjf911 View Post
I had no issues with the generic Glyco main bearing packaging or appearance but they simply were out of tolerance for my crank/case combo while the premium priced official Porsche bearing set from our local dealer was well within spec.
Bringing an old thread back...
Bought the glyco main bearings and also found them .0005 thinner than my old bearings...
So, do gt3 bearings work in a 88 930? Anyone use the calico bearings mentioned?
Old 09-16-2017, 07:12 PM
silver911rdb's Avatar
From what I understand the Glyco main bearings are fine to use in a street or track engines. It's the Glyco rod bearings that are not good for engines built for sustained high RPM track use. The right bearings are the ones made by Automobile Associates with the calico coating. These are available through pelican
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 09-17-2017, 08:23 AM
Chain fence eating turbo
My understanding is Glyco only had a short run of bad rod bearings. I took mine apart after 5 years, and they were totally fine. I'm 600 hp give or take, rev to 6750, so I've definitely put some decent stress on them. I'm sure 8000 RPM stresses more than hp, but no problems on my end.
Old 09-17-2017, 09:55 AM
Both the glyco main and Clevites rod bearings, which is what I have, look fine.
That's not the issue. They are thinner than the old bearings by 0.0005. Making my clearance .001 greater, putting it out of range for spec...
Why they are thinner I have no idea, but they are, as others have noticed... I kind of wonder if Porsche at the factory simply used bearings that were thicker depending on crank size.
Was going to use plastigauge to check case clearance today, but cleaning the case took waaaay longer than I thought....
The crank is in spec, on the low end of spec. Looks new, 55k miles or so. Not a scratch on it. With current old bearings all works fine... Putting in thinner bearings will lower oil pressure...
Old 09-17-2017, 04:44 PM
Ok... updates...
HM Elliot does do coatings, as Ollies posted earlier...
Cost is super reasonable. $5 a pair of rod bearings, $7 a pair of crank bearings...
Adds .0002 to .0004 to each bearing.
They do new and used bearings. The coating is a baked on Teflon coating...
They are doing this for a lot of cars whose bearings are NLA.
Cost is certainly reasonable... $30!
Anyone done this? Thoughts?
Teflon, as far as I know, is a hard substance... Risk to Crank?
Old 09-18-2017, 09:41 AM
gtc gtc is offline
abides.
gtc's Avatar
Teflon is quite soft. No way it could ever scratch a crank, unless a foreign particle became embedded in it.
Graham
1984 Carrera Targa
Old 09-18-2017, 10:20 AM
Really?! Gee my teflon pans are rock hard, can't scratch with a knife...
Old 09-18-2017, 10:29 AM
