40mm phenolic intake blocks
I would like to know where I can purchase 40mm diameter intake phenolic blocks.
I am putting an mfi stack over 3.2 heads. I cannot use the standard phenolic blocks since they have a divot for the injector which will only create an air leak
Old 12-16-2012, 08:53 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Heat Insulators
The above is an web-order supplier of PMO stuff. Pelican should be able to get these as well, even though they may not be listed in their catalog? Maybe check the early 911 part of Pelican's catalog to see if they're in there.
Kevin L
'86 Carrera "Larry"
Old 12-17-2012, 08:33 AM
Phenolic
wow! thanks for the info
Old 12-17-2012, 10:04 AM
