Stranger on the Internet
patkeefe's Avatar
Turbo rebuild leakdown numbers
Hi all:
I did a leakdown test on the 3.0 today. The engine is on my test stand. Historical remarks are that the engine has been apart at least 4 times, I have had it apart three. The engine is fitted with a turbo, homebuilt setup, started as a BAE kit. The engine has Nikasil cylinders, which are amazingly in spec. New pistons and rings are custom JE, which were sized for these cylinders. I finished assembly of this engine about two years ago, but it has barely run since then. Rings may not be broken in.
Leakdown numbers are
1-9%
2-4%
3-4%
4-6%
5-6%
6-6%
I have this afternoon pulled the valve covers, and will adjust the valves to see if there is a difference. They have not been adjusted since the last assembly, so it may contribute to the losses. I can live with these numbers, all things considered, but the #1 cylinder being an outlier concerns me. I am going to recheck in the morning.
Patrick E. Keefe
78 SC
Old 02-02-2013, 04:55 PM
pressurize #1 and bip the rocker arm several times with a plastic hammer to hopefully blow any carbon off the valve seat. i've had them go from 30 to 4 doing that.
206 637 4071
Old 02-03-2013, 07:01 AM
patkeefe's Avatar
JW, I just adjusted the valves, and put the plugs back in. The valves were OK. The plugs were carbon-y black, probably from having the WUR running so rich. I believe your suggestion has a lot of merit in this case, so I will try this afternoon. Thanks!
Patrick E. Keefe
78 SC
Old 02-03-2013, 09:29 AM
