1988 Carrera
shadowjack1's Avatar
One side running
I did a top end rebuild, reground cams to 964 spec., rebuilt heads,all new valves, etc.. Cams set at 1.5 +/- .1. Reinstalled engine, only the left bank is running. I'm getting spark and gas to the right bank but no combustion.
Thing runs on only 3 cylinders.
1988 3.2 lt. Carrera
Cams out of time?????
Just one cam out of time???
What else could it be?
Old 02-05-2013, 06:38 AM
Air Medal or two
afterburn 549's Avatar
You have compression on the non running side?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-05-2013, 06:41 AM
1988 Carrera
I did not check. Going to drop the engine this afternoon and do a leak down.
Old 02-05-2013, 06:48 AM
Air Medal or two
you dont have to do a leak dwn........you are looking for why its not running.
If you have compression on non running side..we can start to look else where.....
Leak dwn is good for some things.......you need a General idea here
a leak dwn is good for a engine all broke in..your numbers will be a bet off no matter what at this point
Old 02-05-2013, 07:24 AM
Shure you did not reverse the right camshaft for 180°?
Old 02-05-2013, 09:08 AM
Swing your dist. 180 and you light off the other side. Your cold side cam is 180 out.
Bruce... been there and done that
Old 02-05-2013, 09:59 AM
been there, done that, ran a bit rough and low on power
Sold: 1989 3.2 coupe, 112k miles
Old 02-17-2013, 02:19 PM
ASE Master Tech - 35 yrs
larrym's Avatar
here is a rare cause:
the right cam sprocket is not engaged with the cam
- either cuz a pin was left out or sheared - loose bolt/nut, or it just stripped cuz the cam seized for some reason
absolute worst case - "somebody" tightened the cam nut/bolt with an impact wrench - it can crack the cast iron & the nose can simply break off after engine starts running -
yes - i did that once about 25 yrs ago on the first engine i ever worked on YIKES
the seized cam - stripped sprocket event happened to me once when oil line got ripped off when wifey ran over a concrete divider one dark nite in Pocatello - engine ran a couple miles before it ran out of oil on one cam and it seized
- she said it had no power those last few miles - the red light did not deter her from driving onward
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-19-2013, 09:44 AM
