How does Bruce know a serial number detail like this? Amazing. Though he has worked on a lot of different motors. Unless, like me, he looks things up - the current parts manual for these cars only lists the 03 cam for the 3.3 turbo, showing the bolt attachment. But at least that is solved - the car has a stock turbo cam, and thus can be timed like a stock turbo.
However, the picture in the catalog also shows two small round looking pins which appear to attach to the far end of the left cam. The catalog says they are for the SC model with Sportomatic. I don't know if the Turbo could be ordered with the Sporto (I would doubt it), or if the turbo cams are drilled for these (drive pins for a Sporto pump?), or if they could possibly fit in there without the special end the MFI cams had and the seal, etc. And they are listed as "roll pin 5x24. If they are 24mm long, scratch that off the list of possible sources for the mystery pin which started this discussion. |
That pin is shorter than the dowel pin so i don`t think it`s the one you mention. I should`ve maby just removed a cam to see the serialnumber or something. I just hought it was weird to put a cam from 1984+ as the cam number 930 143 03 means without it being something special. Guess we`ll know if i have to rebuild the whole shabang
![]() They are timed to about .70 both now so to hell with it Timed and torqued down and covers on. On with the MSD install which i have new questions with.Thanks so much guys
Confusion time!! I should`ve maby made a new thread on this but i`ll see if i get an answer.
When doing the left cam timing i go 360* from Z1TDC and just before Z1 i read from the dial gauge and adjust it from there. The right is the same procedure? Quote:
Saying here that doing the right one should start at Z1 and turn clockwise and just before Z1TDC? Is this correct? Quote:
Here it says do the same on both sides. Confused now ![]() I suspect my right cam is 180* off now. Do i time the right cam at another point from the left? |
Smart quod bastardus
Both are very tiny pins and could maybe have worked there way into the chain housings and been thrown in there when the dizzy was spinning. Its worth inspecting the dizzy since you have it out of the car for this vlave train work anyway. It looks too short to be a chain roller pin. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Ohe - the procedure for timing the right side cam is the same as for timing the left side cam. The cams all turn the same way.
The slightly tricky bit is to make sure they are in the proper phase with each other. When the #1 is at Z1 Firing (both valves closed, spark just went off if running), the #4 should be at the opposite Z1 - the one where both valves are open, with the exhaust almost closed, and the intake just opening - somewhere around a millimeter for stock cams, up to six millimeters (which is hardly just opening, though - that's about half open) for hot race cams on NA motors. If you find that when #1 has both valves closed, and #4 has both valves closed at the same time, you have your cams 180 degrees out and need to reset one of them. Usually the right side ones, to keep from having to reset your distributor if you have installed it. So there is a sanity check for you. |
Walt, if i had two dial gauges mounted one on each side would they be timed at the same Z1 and the dials would move at the same time? I remember that the #1 and #4 pistons where at the same location and that the inlet valves closed at the same time i think.
I think maby my left cam is out because i never touched the right cam. that has been on chain torqued down all the time. Fred: i have found a small pin other places in parts list like on the crank. Still weird since that has not been loosened. |
If it does that, then you have one cam 180 (cam)degrees wrong.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
This means that I should`ve set left cam from Z1TDC on #1 cylinder and right cam at Z1TDC on #4 cylinder which is 360* apart from eachother or 180*on the cams. Will this be correct?
Ah the headache
Yes! You got it! Been there and done this myself setting one cam 180 off... Luckily I discovered it before putting it back into the car.
Plus you should lubricate the advance shaft with oil under the felt cap that resides under the rotor anyway. Too often the dizzy never gets lubed and the advance mechanism can seize up. The fact that you have hard pins like that inside the case worries me though....it could cause tons of damage if it ever went thru the oil pump or through the chain and gear when they meshed.
You might be right fredmeister cause i meant that the crank not has been loosened but the dizzy is out and disassembled. Do you have a good thread on working on the dizzy? I need to mod it for my MSD.
Should`ve just gone with a standalone dizzy free system but don`t have the money now
Basically I ran some steel wire around the counterweight to the post on the mechanical advance plate at their most advanced position to lock them from moving. This way I did not drill any holes or tap screws to lcok them down. Locking them in an advanced position is safe in case they break free of the wire as they can retard timing only at that point.....though centrifical force is going to keep them advanced when running anyway. MSD is the way to go as you can program your boost retard curve which is all important. Good luck.
