Cam Corrosion
What kind of corrosion is this considered?
Old 02-15-2013, 07:37 PM
I'd need to see a much sharper pic to tell for certain, but looks more like deposits related to what oil you use and how often its changed, than corrosion.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-15-2013, 10:31 PM
AlfonsoR's Avatar
i would guess that's light surface corrosion from letting it sit too long without running the engine. What year is the car and how many miles?
"Simplicity is supreme excellence" - James Watt
Old 02-16-2013, 06:51 AM
I wrapped my cams in newspaper when I took the engine apart about 2.5 years ago. I just unwrapped them and the bearing surfaces look dull, kind of like the picture above.
I wiped one down and lobes got shiny again. Any recommendations on cleaning them? Can I polish them with some kind of metal polish or do I need to send them out?
Thanks,
Neil
Neil
'73 911S targa
Old 03-03-2013, 07:06 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
We used to polish cams and bearing sufaces with wet paper...like crocus cloth...and water or light oil.
It gets rid of the surface discolouration and lets you see if there are any imperfections.
For round bearing surfaces...a small wet piece of cloth...and a bootlace wrapped around the outside several times will give you a fast fix.
Bob Hutson
Old 03-03-2013, 07:27 AM
porschetub's Avatar
Moisture in oil
Have seen this in motors that do very short runs,its not pitting of the lobe surface ,don't worry about it,change the oil and give the car a good fast run on the open road if possible.
Did notice from your pic there is light surface scratches on the lobe that can indicate abrasive particles in the oil as mentioned.
Depending on the mileage covered by the engine an oil tank clean may be in order also.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-03-2013, 08:15 AM
