Forced Induction Junkie
WERK I's Avatar
Originally Posted by Cupcar View Post
A very good point. I removed mine to modify them. Cleaning does not require removal.
BTW, Harbor Freight here in USA has a nice bottle brush kit wit brushes the right size to clean the bore.
Another tool you can use is a rifle bore cleaning kit. I believe I used a .22 caliber brush, which has brass bristles. Worked very well.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 04-10-2013, 07:34 AM
Irrationally exuberant
ChrisBennet's Avatar
Like "safe", I remove the plugs and the "indexing" bolt thingy and clean the spray bar in place.
Like "Werk-I"/Dave, I use a rifle cleaning kit. (Shotgun cleaning kit for the case main engine oil gallery.)
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-21-2017, 02:45 AM
WERK I's Avatar
One more thing I would recommend, especially those who have turbo engines, is to clean the spray bar holes that direct oil to the valve train. An opened paper clip will work fine, but if you have a tapered pin that just fits into the hole, all the better. There are three holes per cylinder. This procedure will dislodge any coke bits that have wedged themselves into the spray bar holes.
Once this is done, apply the new spray bar plug to the front of the cam tower, then spray carb cleaner into oil feed hole of the cam tower quickly followed by compressed air into the oil feed. I say quickly because the carb cleaner dissipates very quickly. This will clear any debris out the spray bar and out of the rear of cam tower. Apply the new plug to the rear of cam tower and you're done.
Dave
Old 06-21-2017, 05:25 AM
