Thanks for the nice comment. I'm building the engine itself to stock spec, but I just got a set of B&B headers and plan on a Steve Wong chip.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
I had about the same amount of squeeze out with the three bond on the case perimeter. It looks fine to me.
Looks pretty consistent along the length....I had about the same.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Thanks guys. Always nice to hear the experience of others, especially when wading in uncharted waters as I am.
Hello Ian,
Looks great! As for the squeeze out: It looks very similar to mine. It was one the the 6,798,465 things I worried about. However, absolutely no leaks at all. Henry's method really is good. And, its a balance: Yes, we want full coverage on the bonding surfaces, but we don't want to goop so much on that we end up with globs of the stuff on the inside. I think you are good to go! |
Cleaning rocker shaft bores?
I haver a question about cleaning the corrosion out of the rocker shaft bores.
I don't want to glass bead because that will rough up the surface, so I'm thinking about switching to soda blasting. Has anyone soda blasted their cam towers? If so, did you experience any degradation of the cam bearing surfaces or the rocker shaft bores?
DIY wrencher
Nice work on the engine assembly, at least as far as you posted! What was the outcome in the end, did you get it to run nicely and did it stay dry at the case seam?
Cheers, Lukas
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
