Engine Rebuilder in Northwest
I have a great little '73 911T (Guards Red) with a '75 2.7L engine in it. I'm doing some cosmetic stuff to the engine and redoing the interior and front end, but I think the engine might need some internal attention as it smokes quite a bit; runs well other than that.
I live in Western Montana and while there's a shop here in town that says they can do it, they touch everything from Audi's to Volkswagens. Don't want to spend a fortune but can put the engine in back of my truck and deliver it as I will have it out to do some seal work. Remember, in Montana we drive 500 miles one way for lunch!!!
Your recommendations will be much appreciated.
Tom
Old 04-09-2013, 05:16 PM
Constitutional Liberal
Turbo_pro's Avatar
Supertec Performance, they've done 5 engines for me, every one a gem.
If you'll drive 500 miles for a happy meal , the 1500 mile to Supertec is well worth the drive. Of course you could just ship it for less than the cost of gas.
Take the 15 South turn right at Fallbrook. If you're lucky, stop in Vegas and win the cost of a rebuild......
supertecperformance.com
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 04-10-2013, 09:27 AM
pete3799's Avatar
Porsche 911 Service | Parts | Performance | John Walker's Workshop, Seattle, WA
Pete
79 911SC RoW
Old 04-10-2013, 10:14 AM
Thumbs up
I would also second the recommendation to send it to Supertec, especially a 2.7 engine. You could break it down to the long block, and then send it on a pallet. He should be able to tear it down, let you know what it needs, then reassemble it correctly and with a 2 year warrantee. To do this properly, figure on $10,000 plus, but it will be correct.
At the very least, you should install case savers and the Supertec studs (if they're once again available).
Old 04-15-2013, 11:17 AM
gearhead
Steve at Rennsports Systems in Portland. He will do all the right updates and have the case properly prepped, align bored, etc etc.
John Walker is a great option too. Call both of them and see who you click with.
Old 04-16-2013, 08:31 AM
Straight shooter
Lapkritis's Avatar
Hi Tom,
Have you considered a DIY disassembly/reassembly while sending out for machine work only? Could help the winter pass. Lots of fun.
best,
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-16-2013, 08:50 AM
