Koozy
914magazine's Avatar
901 trans output flange bolt torque?
What is the torque spec on the 901 transaxle output flange bolts? Coarse spline 100mm, in case that makes a difference.
Also, are the output shaft seals a one shot deal. The trans was rebuilt less than 250 hours ago so is it likely I can reuse the seals or will they get hosed when I remove the output shafts from the trans?
More info: I'm replacing the output shafts to go with a larger CV. Dedicated autocross car, 914 with a hot 2.7 is popping CV cages so I'm moving up to 100mm. A common upgrade, known to solve the problem.
Thank you in advance for your time
Mike
Mike Koozmin
1970 911 3.8 CF RSR - Polo Red
1974 914 GT - angry twin-plug 2.7 AX beast
Old 04-21-2013, 09:48 AM
18.8-21.7 lbs-ft.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-21-2013, 10:40 AM
Koozy
Thank you very much, Steve. Greatly appreciated.
Mike
Mike Koozmin
Old 04-21-2013, 12:15 PM
