Koozy
901 trans output flange bolt torque?
What is the torque spec on the 901 transaxle output flange bolts? Coarse spline 100mm, in case that makes a difference.
Also, are the output shaft seals a one shot deal. The trans was rebuilt less than 250 hours ago so is it likely I can reuse the seals or will they get hosed when I remove the output shafts from the trans? More info: I'm replacing the output shafts to go with a larger CV. Dedicated autocross car, 914 with a hot 2.7 is popping CV cages so I'm moving up to 100mm. A common upgrade, known to solve the problem. Thank you in advance for your time Mike
Mike Koozmin 1970 911 3.8 CF RSR - Polo Red 1974 914 GT - angry twin-plug 2.7 AX beast |
18.8-21.7 lbs-ft.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Koozy
Thank you very much, Steve. Greatly appreciated.
Mike
