Puny Bird
Mark Henry's Avatar
Piston sizing for re-plating cylinders, new mahle
I have my cylinders in for re-plating and I have a question on sizing.
My piston clearly says 94,920 etched on it, but that size would be at the top of the pin.
Wayne's book says to measure at the bottom of the pin.
If I measure at the bottom of the pin I get closer to 94.96
I'm assuming the "0" just above the measurement is for "standard 0" SC cylinder size?
Which would be 95.00mm...
But if it is 94.92 then that cylinder spec would be to big...
I'm going to have a machinist friend confirm my measurements tomorrow.
Thoughts?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-14-2013, 02:12 PM
Puny Bird
Mark Henry's Avatar
I found this old thread and Henry explains cylinder/piston sizing. I'm thinking these are "standard 0" pistons so 95.0mm,
Help Identifying This Piston
But if Wayne's book specs are correct I could easily run a slightly higher tolerance like 94.99
Old 04-14-2013, 09:55 PM
