Should Carrera Chain Tensioners be Replaced?
I'm in the middle of my engine rebuild. Car is an '86 Carrera with 175,000 miles. It has the original chain Tensioners in it. Never had any problems with them. Should I replace them while I'm in there or just keep running them?
John
'86 911 Coupe
Old 05-05-2013, 06:44 PM
Walt Fricke's Avatar
I wouldn''t. They have been bathed in pressurized oil all their lives, and just go up and down - not really any side loading.
You could always do the Jerry Woods modification, which prevents them from collapsing more than just a little bit if one goes sour, if really concerned.
When it comes time to put them back in (or right now, getting ready and seeing what you have), you should have to compress them with a vice in order to stick a nail or whatnot into the keeper hole. They should compress rather slowly, with a little oil oozing out of the side of the piston top. If that's what it takes, I'd say they are fine.
If they are very easy to compress, or one is a lot easier than the other, now you have something to consider dealing with.
Old 05-05-2013, 08:34 PM
haycait911's Avatar
what he said. put in the safeties and run 'em.
Old 05-05-2013, 09:06 PM
E Sully's Avatar
Oil Fed Tensioner Modification: ADD SPACER SURVEY
Limiting Travel of the Pressure Fed Tensioners
Ed
1973.5 T
Old 05-06-2013, 04:39 AM
Thanks guys, I'll try the safeties.
John
'86 911 Coupe
Old 05-06-2013, 04:52 PM
