bodmin's Avatar
Changing engine baffles without removing oil return tubes?
Hi - is it possible to change the engine baffles without removing the heads, oil return tubes etc? I suspect the answer is no, but there are so many magicians on this forum I thought I would ask the question.
I have been able to remove one outer baffle without difficulty. However I have no intention of doing intrusive work on the engine (3.2). Just want to change the baffles for cosmetics.
Old 06-08-2013, 06:04 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Expandable oil return tubes.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-08-2013, 07:18 AM
