used cylinders?
I am going to look at some used 3.2 cylinders. What should I be looking for.
Jeff
Old 05-30-2013, 12:58 PM
Trophy's Avatar
Look for sractches, score marks, missing cooling fins etc.
Take a bore gauge if possible, and measure for roundness, and to see if they are in spec (wear)
Steven
1995 - 993 RS Tribute - 4.0l Engine plus other stuff...
2005 - Touareg V8 Tow Vehicle
Old 05-30-2013, 01:00 PM
E Sully's Avatar
Depends also on the pistons. Alusil pistons and Nikasil pistons cannot be mixed in the other type of cylinder. If in good shape you will still see the honing marks.
Ed
1973.5 T
Old 05-30-2013, 01:21 PM
Bring a magnet. Nikasil cylinders will attract on the inner bore surface. Alusils will be non-magnetic.
What is your plan for these 3.2 cylinders?
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 05-30-2013, 03:44 PM
I have a 3..0 SC that I hope to turn into a 3.2ss. A mild 3.2ss with 9.5 pistons. Im not building a race car. Maybe one day......
Jeff
Old 05-30-2013, 04:43 PM
Either Alusil or Nikasil will work. You will get them re-bored to 98 mm with fresh Nikasil plating.
Tom Butler
1973 RSR Clone
1970 911E
Old 05-30-2013, 06:37 PM
Thanks for all the help. I bought the cylinders. There Mahle 98mm . They have no grooves or scraches but may need to be replated. I'll find someone to do an inspection that know more then I.
Jeff
Old 06-02-2013, 08:00 PM
