fred cook's Avatar
Be Careful!
From this point on during reassembly, be certain to keep all of the openings in the block covered or plugged. It is remarkably easy to drop a small nut or washer into the block. Usually they will bounce around until they find the best hiding place! Sometimes the offending piece can be fished out but sometimes it will require splitting the block again! While doing the assembly work on the camshaft timing gears I turned the engine slightly in the stand to the side I was working on was a bit lower than the rest of the block "just in case" a small nut, bolt washer or woodruff key got loose! Paranoid? Maybe, but better safe than sorry!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 09-18-2013, 04:16 AM
Good tip, thanks. I've been using a large plastic bag and various fresh rags to keep any area I'm not actively working on covered. Even while installing the head studs I had all of the cylinder holes in the case covered in case I dropped one of the nuts that I was using to drive the studs in.
I hesitate to say this and jinx myself, but it's gone smoothly so far. Mating the case halves, piston circlip installation, etc. I haven't had any issues or real difficulties up to this point. The cam towers will be a lot of work, and I did buy the RSR rocker shaft seals, so that will be more opportunities to screw something up.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 09-18-2013, 04:37 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Timing the cams is the last hurdle, then smooth sailing. Take lost of pics. If you have an issue it's reasuring to be able to look at the pics and know it was done right.
Lots of people told me my car would never go back together. Ye of little faith.
Enjoy the process
Chris
73 911 E
Old 09-18-2013, 07:40 AM
More progress. Had a lot of trouble getting repeatable measurements on the Cam sprocket alignment last night. Probably just going to stick with the 4 shims on each side that it had before.
Old 09-20-2013, 03:30 AM
Always Be Fixing Cars
Can you tell us why you went with these instead of the $351 option from PP: Pelican Parts - Product Information: 930-110-595-05-M260
I'll be crossing this bridge soon...
Great work so far, look forward to seeing you button it up. It was entertaining for me to read this thread all the way thru, started out thinking "hey that sounds like my rebuild" then "oh boy he's going split case".
Originally Posted by Mr Project View Post
Look what showed up today!
Risk vs. Reward example: I didn't mind spending a bit over $400 to replace fuel lines even though mine weren't leaking. Unknown age and a common failure point that I can address for $400 and not burn the car down? Sold. Whiz, Len is at lenDOTcummingsATverizonDOTnet
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 09-20-2013, 08:27 AM
Straight shooter
Lapkritis's Avatar
Looks great. I had a similar experience and when I did get a repeatable measurement with my straight edge that was within spec, the chain would catch on the sprocket every 4-5 engine revolutions. I think it's a bit of a black art especially with the case seam not being flat between the halves. I would recommend the same - turn the engine by hand about 50 times and observe the chain action and pre-lube it at the same time. Observe if the sprocket is hitting the side of the chain link and adjust accordingly.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-20-2013, 08:44 AM
In my wildest dreams I had hoped to have the engine back in the car this weekend. That's not going to happen, but there has been good progress!
Old 09-22-2013, 03:36 PM
If memory serves, that's just the one line of the three piece set.
All three lines OEM were in the $700-800 range IIRC.
Old 09-22-2013, 04:04 PM
Every night, I think I will have things wrapped up and slide the engine back in. Not yet! Shooting for Thursday night now...
Old 09-24-2013, 03:26 AM
Well, I got distracted again because I had to put up a shed in the backyard before winter hits, but I've been squeezing in late-night time on the 911 wherever I could. And finally, last night, success!
This is after the 20-minute run-in and initial oil change.
video link: VID_20131006_215634_328.mp4 - YouTube
It's been so long that I don't really remember what it sounded like before, but it sounds OK to my ears at the moment, does it to yours?
The only real issue I had when trying to get it started up was that the CHT sensor connection came loose (I must not have had it fully clicked in). That caused flooding and very poor running initially, and since it sounded and felt like a big vacuum leak, I spent a fair amount of time looking for that, plus pulling plugs, doing some compression checking, triple-checking distributor installation, etc.
After the 20 minutes or so of run-in:
  • No massive oil leaks
  • No horrible noises
  • Seems to be generating oil pressure
  • No meaningful smoke out the tailpipe
I have a few things to tidy up in the engine compartment, and then I have a lot of work to do on the rest of the car (interior and HVAC are dismantled, suspension and brakes are only partially assembled), but this is a big step towards driving it again!
Old 10-07-2013, 04:54 AM
Smoove1010
Smoove1010's Avatar
Sounds good to me - congratulations! Great feeling, isn't it?
I hope your neighbor was listening...
GK
Old 10-07-2013, 10:28 PM
OK, here's a breakdown of what I spent on this project and where the money went on this 'Budget' build. Hopefully this is helpful to others in a similar situation.
First up are the items related to splitting the case:
Engine project
Case split items
Machine shop - Recondition rods (big end only, small ends were in good shape)90
Machine shop - measure and polish crankshaft35
ARP rod bolts225
Wrightwood case gasket set100
Case sealant - Loctite 57425
Curil-T sealant14
Threadlocker - Loctite 5718
Machine shop - wash case35
Case-saver insert for bell housing stud11
Chamfer tool from McMaster-Carr20
Kimwipes clean room wipes9
Brake cleaner and other cleaning solvents50
piston oil squirter33
Main bearings (std) 1-7210
Rod bearings (std)152
IMS bearings (inner and outer)32
Assembly lube5
Chain ramps37.5
Piston retaining circlips15
1106.5
Old 10-08-2013, 06:05 AM
Next are the items that were specifically related to the head stud replacement, and then some of my "Scope Creep" items:
Engine project
Head stud items
Machine shop - drill and helicoil exhaust studs on 5 heads130
Machine shop - EDM exhaust stud & EZOut removal on one head118
New steel powdercoated head studs386
New head washers and bolts186
6 sets of rocker retaining hardware (bolt/cup/nut) to replace questionable ones84
Helicoil kit for 6mm x 1.0 engine shroud bolts that snapped30
6 new intake barrel nuts to replace questionable ones42
Extra 6mm engine shroud bolts5
VR head set - gaskets209
Exhaust studs and nuts75
Total1265
Optional things I replaced as additional scope creep:
New fuel lines (all 3 from Len)420
New oil S hose23
RSR rocker seals84
New oil pressure switch at triangle of death5
Cylinder Head Temp Sensor95.5
Used 3.2 crossover pipe (old one broke on removal)99
Summit racing water-based hi-temp engine paint20
Cam oil return line restrictors - turbo31.5
Sport engine mounts48
Total826
Old 10-08-2013, 06:09 AM
Next are the duplicates I ended up with as I either over-ordered due to not knowing what was in the VR gasket kits, or when I changed course to the wrightwood case gasket kit. I bought a Bentley but found it totally superfluous for the engine rebuild. I've used it for other things, so it's not useless, just not needed for this job IMO if you have Wayne's book.
Lastly are the tools I needed to add to the collection. YMMV on these, depend on what you already have!
Engine project
Parts I bought but didn't use/didn't need:
Small end rod bushings (machine shop said old ones were too good to replace)33
VR case gasket set55
Extra set of valve stem seals (came with VR head set)24
Extra set of cylinder base gaskets (came with VR head set)34.5
Oil pump lock tabs (included with wrightwood kit)13
Rear main seal (included with wrightwood kit)21
Bentley manual103
Tools I added:
Sandblasted engine shrouding/air guides/valve covers (bought sandblast cabinet)180
Cam holding tool78
Engine stand yoke45
How to rebuild a Porsche 911 engine book25
Clutch alignment tool9
Old 10-08-2013, 06:14 AM
VERY helpful posts
Thanks for fully documenting this thread and continuing right through to the end.
This is the sort of information which makes this site invaluable to 911 owners.
For example, your SNAFU with the big-end caps is a clear lesson to me to be careful there with my own rebuild. The listing of up-to-date costings is also extremely helpful for reference & comparison - I have already made some decisions using this info.
Peter in Melb.
Old 10-10-2013, 01:50 AM
Great project, well done.
I'm doing the "inverse" (top end and piston rings, no case splitting) and I have a little tiny question for you - what triggered you buying new rocker arm hardware and where did you buy your Wrightwood kits from?
Old 10-10-2013, 05:26 AM
I bought the rocker arm hardware because several of my old sets were rusty and the Allen heads were slightly rounded...I was concerned about being able to torque them down.
I don't want to be disrespectful to our host, I'll PM you on the kits
Old 10-10-2013, 07:05 AM
Shaun @ Tru6's Avatar
Great thread, very timely for me. With the help of a fellow Pelican who has rebuilt a few 3.2s, I'm tackling an 86 with 7 broken head studs this winter. Since it has 150K on it, we are almost certainly splitting the case and going all out.
Tru6 Restoration & Design
Old 11-06-2013, 05:03 AM
