carrerarsr65
79sc row engine rebuild advice
rebuilding my 3.0 row motor i got a set of 40 webers and headers i need some advice on pistons and cam selection any and all advice welcome
Old 06-06-2013, 11:01 PM
Bruce Anderson suggests a GE40 or 911 S cam, in which case he warns that additional valve clearance may be required. See page 145, 2nd edition. Seems that you already implemented all of his other suggestions
Old 06-07-2013, 10:38 AM
Straight shooter
Lapkritis's Avatar
JE pistons of appropriate compression for ignition system (9.5:1 and below for single plug).
WebCam 464/465 cam - good idle, nice delivery if you enjoy a bit of rev.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-07-2013, 11:20 AM
